Plexiglass cover for tube pre?
txcoastal1
txcoastal1 Posts: 13,513
edited April 2012 in DIY, Mods & Tweaks
Has anyone had a custom bulit audio equipment cover built?
Ron
Post edited by txcoastal1 on
    SCompRacer Posts: 9,112
    edited April 2012
    I've had a couple of large custom acrylic covers made for my turntables. There are on-line places that will build to your design but I would check locally first. I had used a fellow on Audiogon in the past but his prices have gone up. I saved over $100 on my last cover going local. Is this for a dust cover for your pre when not in use? (I would imagine a lot of heat building up with a closed cover).
  • thsmith
    thsmith Posts: 6,082
    edited April 2012
    I have one for my TT, I have seen pics of them. I would think the preamp would need to cool some before covering.
  • chargerman426
    chargerman426 Posts: 419
    edited April 2012
    Going with thsmith said, are you planning on having this cover on while the pre is on?
    If life had more tubes it would be a lot smoother.
    edited April 2012
    If your handy you could make one. A router with acrylic cutter would work, then sandpaper and polish the edges, etc.
    edited April 2012
    Would never have it on during use as most would not with their TT just want a dust cover when not using....I had a link a couple weeks ago (which I didn't save) but wanted some input if you have purchased one you're happy with
    edited April 2012
    I've used this fellow on Audiogon before (1854k) but saved a bunch going local.
    http://app.audiogon.com/listings/vpi-scout-cover-plinth-top-stereo-squares-dust-covers
    Sometimes you can find used ones on the 'gon that may fit.
    edited April 2012
    Always surfing the 'gon....should have known better
  • thetawave2
    thetawave2 Posts: 268
    edited April 2012
    If you want something to keep the dust off but aren't completely decided upon acrylic, you can get a custom-made cloth or vinyl cover from DigitalDeckCovers. Check the link in my signature for a testimonial on my blog! This is a relatively inexpensive option. Even acrylic to make a cover yourself can be pretty pricey....
    My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
  • thsmith
    edited April 2012
    A custom fitted cover would be nice, that way you could choose the material to pick your rooms decor. I nice hand towel could do the trick too.
  • zingo
    zingo Posts: 11,258
    edited April 2012
    We have a local place call Tap Plastics that I believe has shops in a couple different states. They will make you custom anything at a reasonable price.
  • thsmith
    edited April 2012
    Here is the link for the people that made my TT cover.
    http://www.jmkdisplays.com/leadtime.html
    S/H for this cover to your zone 6 location will be $25.65 FedEx ground.
    $128.80 + S/H: $154.45
    Please review the following quote and then let us know all is OK and we will then send a PayPal invoice to your E-mail address XX@XX.XX
    1/4"Thk. clear acrylic cover Aas followed:
    WDH: 20.5x15x6.5 (Inside)
    Finger lifts on sides
    The Side Handle Openings Are 4" Long X 3/4" Tall
    Rear Opening Along The Lower Back Side ("Backplate") That Measures: 16" Wide X 1" Tall centerend on back panel.
