Plexiglass cover for tube pre?
txcoastal1
Has anyone had a custom bulit audio equipment cover built?
Ron
Ron
Post edited by txcoastal1 on
I've had a couple of large custom acrylic covers made for my turntables. There are on-line places that will build to your design but I would check locally first. I had used a fellow on Audiogon in the past but his prices have gone up. I saved over $100 on my last cover going local. Is this for a dust cover for your pre when not in use? (I would imagine a lot of heat building up with a closed cover).
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I have one for my TT, I have seen pics of them. I would think the preamp would need to cool some before covering.Speakers: SDA-1C (most all the goodies)
Going with thsmith said, are you planning on having this cover on while the pre is on?If life had more tubes it would be a lot smoother.
If your handy you could make one. A router with acrylic cutter would work, then sandpaper and polish the edges, etc.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Would never have it on during use as most would not with their TT just want a dust cover when not using....I had a link a couple weeks ago (which I didn't save) but wanted some input if you have purchased one you're happy with2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I've used this fellow on Audiogon before (1854k) but saved a bunch going local.
http://app.audiogon.com/listings/vpi-scout-cover-plinth-top-stereo-squares-dust-covers
Sometimes you can find used ones on the 'gon that may fit.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Always surfing the 'gon....should have known better
Thanks2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
If you want something to keep the dust off but aren't completely decided upon acrylic, you can get a custom-made cloth or vinyl cover from DigitalDeckCovers. Check the link in my signature for a testimonial on my blog! This is a relatively inexpensive option. Even acrylic to make a cover yourself can be pretty pricey....My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
A custom fitted cover would be nice, that way you could choose the material to pick your rooms decor. I nice hand towel could do the trick too.Speakers: SDA-1C (most all the goodies)
We have a local place call Tap Plastics that I believe has shops in a couple different states. They will make you custom anything at a reasonable price.
Here is the link for the people that made my TT cover.
http://www.jmkdisplays.com/leadtime.html
S/H for this cover to your zone 6 location will be $25.65 FedEx ground.
$128.80 + S/H: $154.45
Please review the following quote and then let us know all is OK and we will then send a PayPal invoice to your E-mail address XX@XX.XX
1/4"Thk. clear acrylic cover Aas followed:
WDH: 20.5x15x6.5 (Inside)
Finger lifts on sides
The Side Handle Openings Are 4" Long X 3/4" Tall
Rear Opening Along The Lower Back Side ("Backplate") That Measures: 16" Wide X 1" Tall centerend on back panel.Speakers: SDA-1C (most all the goodies)
