So I got some bi-wire
Steve@3dai
Alright, I laid down the 48 bucks to get 16feet of JPW Audiolink Bi-Wire 79 cable.
Banana plugs on both ends.
I haven't hooked it up yet, but plan to in a few hours (still at work).
I'll tell ya what I think
- Steve
Keep this on-topic please.
- Steve
LSi 9/C/FX
Arcam AVR-200
Arcam AVR-200
Post edited by Steve@3dai on
I use a nice set of jumper cables from Pep Boys
sorry - I couldn't help it
Where you will notice the most difference is at the higher SPL's. The system won't sound as 'pinchy' or 'congested'. Put your 'best' wire on the tweeters - unless your best wire is the 'fattest' - then put it on the woofers.Dean
Quicksilver M-60 monoblocks - JM 200 Peach Linestage - Sony DVP-S9000ES - '03 modified Klipschorns
"I'm sure it's better than it sounds."-- Mark Twain, when asked what he thought about Wagner's music -
Actually, I stopped by Pep-Boys, well, Autozone on the way home, looking for Redline brand gear oil for mah WRX
Anyway, so I hooked it up. It's not a night and day, but subtle. The instruments are somewhat more defined, and the stereo image is a tad wider.
I made sure my computer was off, A/C was off, muzzled the dogs next door, to get a clean as possible listening enviroment. I first listened to familiar tracks with the Tara Labs cable. I also made sure the volume did not change in-between the cable switch. Then I switched to the JPW cable. Difference? Yes. Worth $48? Debatable
Here's a pic of the back of my LSi9 with the JPW bi-wire cable:LSi 9/C/FX
Arcam AVR-200 -
I just can't help it, they are so sexy!LSi 9/C/FX
Arcam AVR-200 -
but tell the truth - biwiring looks really cool doesn't it
nice pics of your LSi9's
It's a great tweak for $48 - I've seen people change out CD players and it make absolutely NO difference in the sound.Dean
Well yea it looks cool!
I do need to get a better CD player, but I think I will get a better DVD instead.
- SteveLSi 9/C/FX
Arcam AVR-200 -
SEXY INDEED! nice speakers steve...:D -
whoa - almost 18,000 posts! Juice - you have no life
Have you considered audio as hobby to take up some of your time;)Dean
i'm getting there...
what can i say, it comes down to doing actual work, or surf the polk audio forum all day???:D -
now i can relate to that
i have that problem tooDean
both of us have (5.12 posts per day)
looks like you're just as much of a life as i do...:D
yea, i'm bad
i love these message boards
I actually have friends that still can't figure out a woofer from a tweeter and could care lessDean
of course, you've got the 'one of a kind' polkie wannabe id, so your one-up on me...
what does it take to get your own personalized id around here???:p
that's it, i'm gonna gonna go buy some klipsh's... (hint hint):D
