Are Polk LSI9's and Denon AVR3312CI a good match???
Sean_Heins
Sean_Heins Posts: 9
edited April 2012 in Electronics
Thinking about picking up some Polk LSI9's and Denon AVR3312CI to power them.
I can get the receiver for about $680 (pretty much my ceiling). I play vinyl often (Music Hall 5.1) so having a phono pre-out is important... or I can get a preamp, but that would cut into receiver $$$. I also want surround capabilities. Is this receiver (Denon AVR3312CI) my best option that includes a phono? Will it power the LSI9's? I'm just not sure if 125 watts at 8 ohms is going to be sufficient for the 4 ohm Polks, although I haven't settled on the Polks. I will use the receiver equally in stereo and a 5.1 surround set up. Any other suggestions within the $680 range are welcome.
My very first speakers were some Polk bookshelfs- I am thinking of upgrading to the LSI9's and using the old Polks for surrounds now, but am also open to suggestions or comparable speakers. I considered some Def-Tech 40's as well. I have not heard them side by side but I recall liking the sound of both. It has been a few years though. I also just purchased the Polk DSW Pro 500 sub- not sure if it will matter with matching sound of sub and speakers.
Thanks in advance for any input!
Post edited by Sean_Heins on
    heiney9 Posts: 25,405
    edited April 2012
    No not really, not to get the best from them. If you keep the level down it will do. Does this model have pre-outs? If so that gives you the option to add an amp so you won't be stuck later on. What are you running for surround speakers?
  • rooftop59
    rooftop59 Posts: 8,121
    edited April 2012
    Welcome ot Club polk.
    If you do a bit of searching around, you will find lots of info on proper amplification for the Lsi series. I would suggest buying a slightly less expensive (preferably used) receiver that has pre-outs and then a 2 channel amp such as an adcom 545 or 555.
    Good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • Sean_Heins
    Sean_Heins Posts: 9
    edited April 2012
    Yeah, it has pre-outs, but I would be broke after the purchase so they wouldn't do me much good for at least a year. Kind of sad... I was going to use some old R1's for the rear surrounds.
  • mole'
    mole' Posts: 3,160
    edited April 2012
    680 for a AVR3312CI is a good price.
    is that new?
    that AVR has Pre-outs. you could add on an ext amp later down the line.
    mole'
  • rooftop59
    edited April 2012
    So why no go for a slightly older model like this one:
    http://www.ebay.com/itm/Denon-AVR-3310CI-7-1-Channel-Home-Theater-Receiver-/200738627562?pt=Receivers_Tuners&hash=item2ebcf45fea
    Buy a square-trade warranty and an external amp and you will be blown away by the sound...
    Game Room 5.1.4:
    Bedroom 2.1
  • Sean_Heins
    Sean_Heins Posts: 9
    edited April 2012
    That would definitely be a good option. Thanks for the link.
    When I saw the 3312 I just got really excited becuase it has "Air Play" so I could finally enjoy all my music from my computer effortlessly.
  • Sean_Heins
    Sean_Heins Posts: 9
    edited April 2012
    It is not new, but its actually $579!
