Carver TFM-35 humming
newbie308
I noticd recently that my two channel system has started humming, and I have diagnosed the source of the noise as the Carver TFM-35 Amplifier. The intensity of the noise is proportional to the gain. I first noticed it a few months ago, but the noise was faint, and didn't affect the listening experience at lower volume levels. Now I can hear the hum at 25% of full gain, and it is time to remedy the situation. I was wondering if some new capacitors in the power supply would cure this? What do you suggest?
Post edited by newbie308 on
Very possible the caps are bad in power supply, I would start there myself. Good Luck.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Mess with the RCA inputs on the TFM-35 while it is powered up. Just a counterclockwise twist here, clockwise twist there, see what happens.
^^ Good point also.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I like the easy solutions. I will definitely give the rca connectors a twist! thanks!Enjoying the journey while never attaining the destination.
It could also be the preamp. Hook a CD player directly to the back of the amp (make sure the gain knob is all the way down) and see if the hum is present as you slowly increase the volume with the gain knob.SDA SRS 2.3TL's
SDA 2B TL's -
Good point about the RCA connections. Just tonight I was listening to a CD and noticed that the output was less on the right. After checking that Source Direct was selected, eliminating the balance and tone controls, I de-mated and mated the CD connections. That was it, all balanced again.
StanStan
Main 2ch:
HT:
Other stuff:
