pa1200.1
ipartywhenuhurt
I just purchased one from pa ebay store and im unsure on how to hook up the power cables. I cannot take of the cover to get to the screws on the power terminals
please help
Post edited by ipartywhenuhurt on
Nothing just a paper saying i bought them from the pa website. the amp smells like electrical burnt but only lightly.
Hello,
Here's a link to download the owner's manual:
http://www.polkaudio.com/downloads/manuals/home/PAamp_Monoblk_WebMN_31March08.pdf
Regards, Ken -
In that manual it doesnot say how to take it off
so i wanted to ask people with experience -
Hello,
You indicate you don't know how to connect the power cables? Figure three in the owner's manual shows 12VDC, ground and speaker wire connections without removing anything.
Are you wanting to remove the amp's cover and look at the circuitry?
Regards, Ken -
I figured it out, you have to remove the amp cover to be able to get to the power/ground/remot/speaker connections. It gets rid of the bar thats covering the screws that u need to loosen to be able to fit the wire in
Also on the amp i got from u guys i was having trouble removing the amp cover since the screws were striped already and i can see that being a big problem in the futur. Ill see if i can get new screws before i put the cover back on
Thanks for your help:)
