3.5mm to Toslink?
specd_out
I was looking to get a new 3.5mm to rca and I stumbled across a Audioquest 3.5mm to Toslink. What exactly would be the reasoning behind this kind of cable. Its labeled with 3.5mm first so i am assuming the source outputs via the 3.5mm.
HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator
Post edited by specd_out on
A number of apple products (mac laptops, mac mini, and airport express) can do optical out of the audio out/headphone jack. This is a fully optical digital cable. One end is just 3.5 mm to fit the headphone jack.
Oh ok so a device has to be able to send optical out via a 3.5mm jackHT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
ISF Level 2 Certified Calibrator -
Correct, before I went the USB DAC route with my iMac I had one of those cables to get the digital output from my computer to a regular DAC.
think of it as a Toslink cable with a different connector for many Apple products. you still get digital signal, there is no A/D conversion going on.
These were also common on portable Minidisc recorders.
Monster AVL-300, HTS-2500 MKII -
Yes - MD players had them as well as some sound cards. My X-Fi Titanium HD uses the 3.5mm toslink -you just add the tip to the end of a regular toslink cable so it fits in the audio jack.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
AsSiMiLaTeD wrote: »Correct, before I went the USB DAC route with my iMac I had one of those cables to get the digital output from my computer to a regular DAC.
Why did you pick USB over the mini TOSLINK option?HT
Onkyo TX-NR1008 | Magnepan 1.7 | Polk LSiC | Polk VM20 | Polk DSW microPro 2000 | Parasound HCA-2205A | Oppo BDP-93
2-Ch
Cary SLP 30 Tube Preamp | Polk LSi7 | Carver M1.5t | Audio-gd Digital Interface | W4S DAC-2 | MAC Mini | Denon DP300f & Pro-Ject Debut III TT's
