660wi shorting?
Glowrdr
Glowrdr Posts: 1,103
So I've got a 660wi that seems to have a short in it? The blue light on the front does not turn on, and the green light on the back turns on for a spilt second, then it turns red and green again for a split second. I'd say if I had to measure it - it would be 8/10'ths of a second would be a green light, 1/10 of a second would be a red light, and the other 1/10 of a second the light would be off.
Is there some way to reset the sub? I also noticed that my receiver kept changing into Pure Direct mode (on multiple occassions) and I had to switch it to something else.
So is this a 660Wi sub issue, or an issue with my SC37? I doubt its an issue with the reciever as I'm driving what would be considered one of the easiest setups in the world. But.... something isn't working right and I need to figure out what it is. :redface:
65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa"
Post edited by Glowrdr on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited March 2012
    Hello,
    The best way to check out the sub is to connect the Oppo's right and left audio outputs directly to the sub's inputs with the sub's volume set at zero. Then start playing a CD and slowly increase the sub's volume level.
    Regards, Ken
  • Glowrdr
    edited March 2012
    The sub does this with nothing connected to it - I think I'll pull the plate/sub and see of something came loose. Otherwise it looks like I'll be sending it in. I'll post back and let you know - I'd need more info if that's the case.
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • Glowrdr
    edited March 2012
    Took the plate of, and everything seems fine from what I can tell. Put it all back together, and the amp still wants to power cycle itself
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • [Deleted User]
    edited March 2012
    Hello,
    I don't believe there is anything else that you can try. It would be best to contact Polk's CS department either via telephone at 1-800-377-7655 or email at polkcs@polkaudio.com.
    Sorry for the problem, Ken
  • Glowrdr
    edited March 2012
    No worries - never had to deal with Polk, but I'm sure they will take care of me. Thanks for the help though
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • Glowrdr
    edited March 2012
    Called Polk CS and gave them all of the troubleshooting that I've done already, they asked a couple other questions - and within 10 minutes of being on the phone, I have a new amp on it's way.
    Those people complaining about Polk CS really just need to pick up the phone. I'd like to take this time to give a shoutout to my CS rep Ms. Diaz!
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
