Belkin Pure AV PF60 for $124.99 w f.S.@ Buy.com today
Dabutcher
Dabutcher Posts: 2,604
edited March 2012 in Electronics
I have one that I enjoy and I have bought from Buy.com Before w no issues. Fair price for this unit.. Peace,Darryl
Post edited by Dabutcher on
  • kuntasensei
    kuntasensei Posts: 3,263
    edited March 2012
    Thanks for the heads up. Been considering one of these mostly so it can power up my Adcom amp when my AVR kicks on, because I don't want to keep using the switch on the front, but I don't want to leave it on 24/7 either.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2012
    No 12v trigger between your AVR and amp?
  • pdxfj
    pdxfj Posts: 376
    edited March 2012
    Ahh.. Thanks! Just ordered one.
    I leave my amp on all the time. One less thing to turn on and off..
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited March 2012
    No silver series !!!!! nooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2012
    bah humbug---nothin a little krylon can't fix.
  • kuntasensei
    edited March 2012
    Nope. Adcom GFA-5503 doesn't have a trigger. Still kickin' around whether to get one of these though, since it only handles 1,800w of gear... and the two amps I want to power on with it are 1,600w on their own. I guess I could get it and just use it for my receiver and two amps.
    Equipment list:
    Emotiva XPA-3 amp
  • NE1410S
    NE1410S Posts: 44
    edited March 2012
    Finally got in on the deal. Thanks for posting Dabutcher!
  • steveinaz
    edited March 2012
    It's a nice unit, just got one about 2 weeks ago.
  • kuntasensei
    edited March 2012
    Crap! My Onkyo 1007 doesn't have a trigger either! Only has triggers for Zone 2/3! Man, I guess I still gotta GET UP to turn the amps on. :eek:
    Equipment list:
    Emotiva XPA-3 amp
  • michael1947
    michael1947 Posts: 775
    edited March 2012
    Thanks for the hot tip, I just purchased a pair.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • zeppage2
    zeppage2 Posts: 196
    edited March 2012
    Will this help?
    http://shop.emotiva.com/collections/accessories/products/et3
  • polrbehr
    polrbehr Posts: 2,841
    edited March 2012
    I've got two PF60s, they're excellent units.
    And both of mine are silver, wish I could grab one of those from buy.com. Wanna trade?:lol:
  • PrazVT
    PrazVT Posts: 1,607
    edited March 2012
    I ordered one too :)
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • kuntasensei
    edited March 2012
    zeppage2 wrote: »
    Nope... 'cause the 1007 neither has a trigger out nor a switched outlet (which I never realized until I looked at the back panel in the manual). Kinda' crappy of them to only provide triggers for Zone 2/3 operation.
    I went ahead and bought the PF60 though. My cable box has a switched outlet that I've been using for a couple of LED lights that come on with it to backlight my projection screen very slightly. Shouldn't be a big ordeal to use that switched outlet to kick on the amps and the two LED lights. It just means that the cable box and LED backlights will have to be on when I'm listening to music, whereas my Harmony normally just has my Oppo and AVR turned on for that. Minor bit of remote programming should take care of that.
    Equipment list:
    Emotiva XPA-3 amp
  • kuntasensei
    edited March 2012
    Got my PF60 in, hooked everything up and now my amps power down with the cable box (since my AVR has no trigger). Kind of a half-**** solution though, 'cause if the DVR kicks on to record something, the amps are going to come on. No other way to trigger them though with my current setup.
    Still have that brutal hum in my Samson 1000 unless I use a cheater plug. I was kinda' hoping that the PF60 would let me get rid of that cheater plug, but oh well. That thing is just destined to hum unless the ground is lifted. Not too concerned with it, since I'm probably gonna ditch it for a Crown amp in the not-so-distant future.
    Unfortunately, I'm also noticing a very slight hum in my Adcom. I pulled the ICs to see if it was coming from the AVR, and even with them disconnected, I can hear it. It isn't obtrusive... You have to be within a foot of the speaker to even hear it. Still, it concerns me. Haven't tried a cheater plug on it yet, but if that works, what does that mean? Ground problem? I've isolated everything as much as possible, am using a ground filter on my cable box, and our power is properly grounded at the box.
    Oh, and the pictures of the PF60 do it no justice. That sucker is WAY bigger than I expected. I had to rearrange my gear a little to get everything wired up. The big surprise to me was how little I'm actually stressing that circuit. I was afraid that I was pushing the boundaries, but even with all my gear running and the volume cranked, I never got it to go higher than 6.1 amps.
    Equipment list:
    Emotiva XPA-3 amp
  • PrazVT
    PrazVT Posts: 1,607
    edited March 2012
    Mine got hooked up yesterday as well. So far so good!
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • kuntasensei
    edited March 2012
    Figured out the hum in my Samson and it has nothing to do with the power. A friend of mine deals with pro-audio gear and it turns out that the Samson 1000 has balanced 1/4" TRS inputs (3-conductor), not unbalanced 1/4" TS (2-conductor). That means that for the entire 6+ years I've had my SVS setup, the cables SVS had provided with it (unbalanced RCA to unbalanced 1/4" TS) were incorrect. Basically, the 1/4" TS is shorting the ground with the negative lead of the RCA... and since pro-audio gear grounds the balanced ground to chassis, unless you lift the ground, HUMMMMMM. So either I can find someone to make me a custom cable (since no one I can find sells unbalanced RCA to balanced TRS), or replace the Samson with a Crown that has RCA inputs. Nice that it only took me 6+ years to figure this out, huh? :cheesygrin:
    Equipment list:
    Emotiva XPA-3 amp
