I had the MM12 hooked up to a C500.1 amp and it blew the speaker in less than a day.
north
north Posts: 2
edited April 2004 in Car Subwoofer Talk
I was wandering if the C500 monoblock amp. would be able two power two of the MM12's? Would it be even worth it?
Post edited by north on
  • 97FordExp.XLT
    97FordExp.XLT Posts: 20
    edited April 2004
    did you just crank it?
    '97 Ford Explorer XLT
    - Clarion Pro Audio Reciever
    - RF 500Watt Amp Bridged
    - 2nd MM12 smoked from replacement warranty
    - Infinity Kappa 5x7" rear doors
    - Infinity Reference 5x7" with tweeter front doors
    - Kenwood 60x4 4 Channel Amp
    - Lightning Audio 1 Farad Capacitor with distribution and digital voltage monitor
    A society whose citizens refuse to see and investigate the facts, who refuse to believe that their govt and their media will routinely lie to them and fabricate a reality contrary to verifiable facts, is a society that chooses and deserves the Police State Dictatorship its going to get.
    "Every great advance in... knowledge has involved the absolute rejection of authority. ~Thomas Jefferson. EXERCISE YOUR RIGHTS and DONT BE A MINDLESS ZOMBIE, THINK FOR YOURSELF!
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2004
    actually, a 300.2 to each woofer would be a much better match. the monoblock would work, but wouldn't be as powerful. and for the love of phil, properly break in your subs before cranking them. there's been a lot about this recently, look around a little bit to learn how. and it takes longer than you'd think.
  • exalted512
    exalted512 Posts: 10,734
    edited April 2004
    you did something wrong if u blew it off that amp
    -Cody
  • Airplay355
    Airplay355 Posts: 4,298
    edited April 2004
    how are u running two subs off the same mono amp? are then in a series or parallel? either way changes the imp of the subs. might be the reason for whats going on. if they are run in parallel that will drop the impedance making the amp working harder and bringing about more distrtion, which cooks subs. i dont think running 2 subs off the same mono amp is such a good idea.
  • exalted512
    edited April 2004
    actually its a great idea...thousands of people do it
    -Cody
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited April 2004
    You're right cody... in fack most of kickers line and plenty of others have two hookups, but it's really a mono amp. designed to run two in parallel from the start. Besides, mono for subs is better, as you will not be wasting any power on sounds that cancel from right and left channels, the mono amp cancels them BEFORE powering them.
    And Please break in your subs, shooting the parts off after a day is not a bad sub in most cases, just not allowing the parts to get used to moving first. and you can always extend the life of rubber parts with a little care from a pure furniture oil.
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • Airplay355
    edited April 2004
    wouldnt it be easier on the amp to just get two seperate monos? wouldnt that give u more headroom to turn it up too? because things arent working as hard?
  • neomagus00
    edited April 2004
    mmmmm.... you're right, technically. distortion and the like do go up as impedance drops, and yes, there will be additional headroom, and yes, the load on the amp is less, and yes, it does control the sub better - but all of these in very very small amounts. for extreme quality speakers, focals or somesuch, you may notice, but for subs its no deal.
  • exalted512
    edited April 2004
    technically, it would be easier on the amp to run at 4 ohms than at 2 ohms
    but the amps are made to run at 2 ohms so it doesnt really matter
    no it doesnt give you more headroom
    headroom is how much more watts you have left over when your subs cant take anymore
    ex: some sub can take 500 watts, you have a 600 watt amp
    1 amp is easier to install than 2
    2 amps looks cooler
    if you have 1 amp, and it blows, youre **** out of luck
    if you have 2 amps, chances are both will not crap out on you at the same time
    ive had both 1 amp for 2 subs and 2 amps for 2 subs
    and ive also blown the 1 amp for the 2 subs
    ive also blown 1 of the 2 amps also
    i must say it is VERY nice to still have one sub bumping than no subs at all
    plus
    2 channel amps are going to sound better than mono amps
    just the way it is
    another drawback though is that 2 channel amps draw more current than mono amps
    i really cant say which setup that ive had that i like better
    my next 2 sub set up will be powered by one amp though
    mainly b/c its easier to set up and it draws less current
    -Cody
