Nad M25 / Parasound A51 / LSiM Series / HT Use 80%
RocketOCannon
RocketOCannon Posts: 86
edited June 2012 in Electronics
Considering buying one of these two amps. I think I really want the Parasound...great amp..gobbs of power.
These will be used in a 5.1 HT set. powering LSiM 707s, 703s, 706c and Micropro 4000.
My concern is underpowering the speakers and also...maximizing the speakers potential between these 2 choices.
Here is what someone discussed with me regarding the two. I would like some feedback with you folks who know more then i do about the technical side of this.
Hi Rick,
I did some research on the products you planned on using and did a little math based on the specs given on their respective websites. Without even getting into games played with wattage numbers (for example, I can't help but notice the THD number(0.2%)used on the Halo A51 rating is above what NAD considers clipping) we can look at the basic numbers to see what the difference would really get us. If all other things are equal, and we compare the Halo A51 versus the NAD M25 with the speakers mentioned, here's what we need to look at:
The Polk LSiM 707 is rated to 88 dB/W/meter
Doubling power gains us 3 dB (the smallest increment of volume the average person can reliably detect).
So the raw numbers provided the differences in stated power are:
Halo output - 111.98 dB
NAD output - 110.04 dB
So I guess the real question is: why 250 WPC? The difference between the NAD's and the Halo's output will be minimal, practically undetectable. The room isn't terribly huge and you probably won't be playing your system at reference levels most of the time. I know you were worryied about damaging the speakers from underpowering them which is a valid point if you were talking about using a Yamaha or something like that where distortion is a huge issue at high volumes. Distortion is what will damage the speakers and NAD will play at practically the same volume levels as the Halo with a lot less distortion. Also, NAD comes with a smaller price tag.
Thoughts?
Advice?
Opinions?
Reviews for both seem excellent. Just want to make sure I choose what I need...or continue looking at some other options. Pre amp is still TBD.
Thanks,
HOME THEATER 5.1
JVC DLARS56U
92" SI Black Diamond 1.4 16:9
NAD M25 MC Power Amp
Marantz AV7005 Pre Amp
Oppo 95
LSiM 705 Fronts
LSiM 706c
LSiM 703 Rears
SVS PB13 Ultra sub
ZONE 2
LSIM 707 (2 Channel Sessions)
McIntosh MC312
McIntosh C49 Preamp
Marantz SA8005 SACD/CD Player
79' Pioneer SX-1080
Furman Elite 15 PC
SolidSteele HF-4 series rack
REL Carbon Special Purple Label
(Building system out currently)
(Use Quobuz almost exclusively - CD/SACD Part time)
OUTDOOR DECK
NAD C 375BEE DAQ
PSB CS 1000 Speakers
Sonos
Signal Cable - Ultra Single (Banana), Magic Power Cord, Dig Power, Vid Power.
RTi T3-V+, SONOS, Furman Power Conditioner
Post edited by RocketOCannon on
  • pearsall001
    pearsall001 Posts: 5,251
    edited March 2012
    Tough call, they are both beasts to be reckoned with but the NAD is a 7 channel amp which will give you room to grow down the road if you go to 7.1. The A51 is a 5 channel amp. Both will do the job in spades & will power any other speakers you might have down the road. I would go with the M25 & pocket the savings.
  • newrival
    newrival Posts: 2,017
    edited March 2012
    I'd recommend looking into other brands as well: bel canto, wyred 4 sound, etc.
  • RocketOCannon
    edited March 2012
    All,
    Thanks for the insight.
    If anyone else out there has thoughts or insight please chirp in. :>)
    I know they are both nice amps. Me being not up to speed with all this, I was more concerned with the neanderthal thinking of wpc. I wanted to get an amp that would get me in the ball park of the rated 300wpc of the 707s, still provide clean power and try not to sell the dog and the wife to accomplish it.
    Sounds like the NAD is just flat out more efficient even though I probably can't go wrong with either one. The truth is, I won't be listening at reference levels and if I do it will most likely be for "Show-off" time anyway...
    Is there any specific amps in this ball park that I should do some homework on? ...it would be very helpful if someone noted amps "A, B, C" to check out. I will look around the co's listed above as well.
    Thanks, I appreciate the info. It really helps me make sense of the homework I have already done.
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
    tonyb Posts: 33,069
    edited March 2012
    Change your mindset, get off the watts thinking, especially the recommended watts for speakers. Current is whats needed, not high wattage. Most any SS amp in the 150 watt range and up will have enough current to drive those speakers to their full potential.
    Other amps ? New or used ? Budget ? Don't forget cables, leave some coin for some good cables.
  • ambiophonics
    ambiophonics Posts: 727
    edited March 2012
    Just for the record, I believe 1dB is the smallest increment of volume the average person can reliably detect. A 3dB increase would require twice the amount of power.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • RocketOCannon
    edited March 2012
    My thinking has changed. the numbers make sense. I will keep snooping around but this advice has allowed me to zero in towards a few units to make a final decision on based on the details.
    I think Im willing to spend just north of 3g on amp...looking at used, unless a dealer wants to make it happen for "new" a little above cost. I have actually had some luck with this approach. Regardless of where and how I make my purchase..it will be determined by the situation at hand and funds available at the time I decide to buy. I know some folks on here will disagree with this approach... but...I will live, learn and take my lumps if need be.
    My thinking is the money saved on used for my overall system will pay or help pay for any problem that might come up where i need to send a unit in for work. If it happens..it happens...I'm willing to take the risk where the product will not be backed by a warranty. Although perfect world I would love to have a warranty for everything I buy...just can't get to the system I want by doing that ($)
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
    tonyb Posts: 33,069
    edited March 2012
    This is all you need,
    ....and will make those speakers sing. Musical, a tad on the warmer side for those LSI's, and balls to blow out a window or 2.
    http://app.audiogon.com/listings/b-k-reference-200-7-200w-x-7-8-ohm-375-w-x-7-4
  • RocketOCannon
    edited March 2012
    Kex...interesting insight. Thanks!
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • RocketOCannon
    edited March 2012
    tony,
    Thanks, that is one of the ones I will be looking at when it comes time to purchase. It's always been on m shortlist. Not quite there ($) yet.
    What are your thoughts of that amp vs the NAD for my system?
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • pearsall001
    edited March 2012
    I had my heart set on picking up a used NAD M25...but a killer deal on a Rotel RMB-1095 5 channel amp feel into my lap, I just couldn't pass it up. The amp is a killer & I'm quite happy with it & of course the $$$$$ savings that also came with it. To be honest there's no need to spend 3K large to get a great amp...just my thoughts.
  • RocketOCannon
    edited March 2012
    Pear,
    I agree. If I was ready to pull the trigger I probably would grab the B&K Ref 200 on Audiogon right now. Gonna have to wait a bit still due to wifey having the lockbox on the funds for a little while longer. Once I get the green light. I will look for one of these amps and look for the best deal.
    However, this NAD looks to be real nice...smooth...Love the THD #.
    Any thoughts or insight to the Marantz pre AV7005? ...or another pre that I might consider for my planned system?
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • RocketOCannon
    edited March 2012
    Kex,
    Interesting chart. Great graphic. I agree that if I plan on $$1,500or north of that will get me a sweet amp.
    I have been reading many different reviews...did not see that one. Im not concerned with the fans...no biggie.
    I am certainly leaning towards the NAD as well since it is 7ch vs 5. I will be adding the FX LSiM surrounds at some point down the road.
    I have a pretty good idea of what I want in my power amp...now need to start the journey on learning about the per's.
    I have learned a ton from everyone on the CP site that has helped me...Tony, Mantis etc...and a ton others. I appreciate it.
    Let me know if you have any thoughts on pre's as well.
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
    tonyb Posts: 33,069
    edited March 2012
    All the amps your looking at should be great, but seriously, the THD #'s are pretty much negligent, you wouldn't hear that difference anyway. Oh, don't get too razzed up by reviews my friend, it is the internet after all and you can probably find a good review on a **** too. Pay more attention to the sound signatures of the amps and make sure they compliment your speakers. In other words, don't buy a bright sounding amp and pair it with bright/forward sounding speakers. See what I mean ?
  • RocketOCannon
    edited March 2012
    For sure Tony...I'm learning fast...but so much further to go! lol I also try and read reviews as critically as I can...i know there some horse crap out there with the politics of business etc...but they give me a feel for the product I'm looking in to. My ears will tell me the bottom line.
    I will also be doing my due dill on trying to listen to the amps prior to buying.
    I've asked this question a few times...does anyone have any opinions on the Marantz AV7005? ....again..lol..good reviews...lots of features and I can get a pretty good deal new. I know nothing about pre's. I am reading about them and learning more but could use some insight here.
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • RocketOCannon
    edited March 2012
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • iskandam
    iskandam Posts: 704
    edited March 2012
    At one of my local craigslist finds, the seller has a Marantz AV7005 hooked up to the Parasound Halo A51 to power a set of older KEF's. It's a small duplex, so totally overkill for that space, but the sound is amazing. I don't know how much more you'd have to spend to get a significant jump in sound quality from that set up.
  • RocketOCannon
    edited April 2012
    Im to Giddy not to post.... I scored a NAD M25 - excellent cond on eBay yesterday for $1,500! Be here early next week but can't hook it up since I still have pre amp, speakers etc to buy (LSiM).
    But I am "P-U-M-P-E-D"! Like a little kid...I will probably just sit and stare at it...lol
    My system is starting to take shape and the basement / HT construction is scheduled for end of May.
    Sorry to bore anyone...just pumped to get that amp at a great price! No one else bid.
    AHOY!!!
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2012
    EndersShadow Posts: 17,697
    edited April 2012
    Pics or it didnt happen :smile:
  • RocketOCannon
    edited April 2012
    lol
    I only have the 707s currently and the NAD will be here next week...kinda boring pics...lol...but as soon as I get all my gear I will def take some pics. I will take pics as the basement takes shape as well. still working out details of equipment placement/closet etc.
    I will be buying the 703 rears, 706C and MicroPro 4000 fairly soon. Im also going to stretch some $ and get 2 more 703's for 2 channel listening. And yes for those thinking it...i am going broke and the wife is disgruntled,...but, I don't care! lol Honey Badger don't give a $h-t!! lol
    Fyi - I could have gotten the M25 new w warranty for $2,600...but the spread was to big...went with the used.
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • PrazVT
    PrazVT Posts: 1,607
    edited April 2012
    Congrats!! I too am a proud owner of this 96lb beast :cheesygrin:
    The M25 has plenty of power and I suspect NAD rates these amps conservatively. It's extremely clean and detailed - I too was pondering getting the A51 at the time (I had an A21 previously) but read some good reviews on the M25 and decided to give it a shot.
    As for the fans, about the only way I know they are there is a very slight breeze if I keep my hands over the top cover. Anyway, do give us your thoughts once you've had some time with it!
    - Praz
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • RocketOCannon
    edited April 2012
    Kool,
    lol...I was eyeing the same one listed earlier on AG (I think?) Same picture etc...but couldn't pull the trigger. I saw it on eb..and made my mind up and just did it! It's still enroute from seller. As mentioned above...I can't even listen to it yet till I get my preamp etc...so I'm just gonna stare at it like a dog staring at his ball hoping it moves! lol
    Congrats on your Parasound A51...sweet amp too. Can't go wrong with either one and I am sue you will love it. The more I read...the more I wanted the NAD...got it..psyched!
    I will be sure to take pics as my HT takes shape and I can finally get the rig up and running. If I snagged the A51...I would be just as happy.
    enjoy your amp and again good snipe!
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • truwarrior22
    truwarrior22 Posts: 18
    edited April 2012
    Congrats on the NAD25! Out of all my gear, I'm most proud of it :)
  • RocketOCannon
    edited May 2012
    A quick update
    Im going with a SVS PB12 Plus sub in place of the Micropro 4000
    Anyone have any thoughts, comments opinions on this sub?
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
    edited June 2012
    SVS is a good company and that sub is pretty kick butt if I remember correctly...
  • RocketOCannon
    edited June 2012
    Things are getting hotter around here! :>)
    Got my Oppo 95 today...pumped!
    Nice packaging. Very good looking unit. Need to get the Marantz AV7005 PRE next. Then I can get to use the M25, 707s etc in my bedroom while the basement is constructed starting in July.
    Getting closer to placing my big order $ for the TV, speakers, pre and cables soon.
    Looking to go with 705s as well. I figured if I need to spend $1,200-$1,500 on (4) 703 speaker stands...I might as well put the $ in to the 705s instead of metal and lead shot/sand. This way I will also get to hear and understand the full LSiM lineup. I can interchange them throughout the system to see where they best fit in with performance strengths.
    My plan now is still 5.1 to start
    707s - 100% music / Zone2 other side of basement
    705s - HT Fronts
    703s - HT Rears
    706-Center
    SUB - SVSPB12
    This way I can us the "Full Throttle" 707s on the other side of the basement where it will be 100% music.
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
