Sunfire Classic tube preamp????
warviper
warviper Posts: 585
edited April 2004 in Electronics
Any thoughts? Just got my self a sunfire amp and verry happy with the sound but its runing through my yammy avr rx2300 and Im gonna move it to the bedroom and make a pure two channel rig with some sda1cs that Im getting. But back to the point, I should be getting a good deal on it, by the way how much should one of these go for new, and I wanna get into tubes but if the sunfire is crap please let me know or if there is better out there I wanna know also. Thanx for the help.:D
Wish I was a polkologist then I could call my self Dr.warviper.
Post edited by warviper on
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited April 2004
    Better ? There's always better out there regardless of where you draw the line. You wanna spend $25k for a tube preamp that MIGHT be the best one out there ? You can ...
    The Sunfire is about $1500 MSRP and half that used.
  • warviper
    warviper Posts: 585
    edited April 2004
    PW of course I meant comparable to the cost of the sunfire.:rolleyes: Thanx for the quick response.
  • amulford
    amulford Posts: 5,020
    edited April 2004
    I kinda doubt it's crap, dude. Don't you like the amp?..
  • warviper
    warviper Posts: 585
    edited April 2004
    I like the amp but I have heard that the sunfire sounds dirty because of the tubes. the tubes are change able right?
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2004
    You can roll tubes in any tube Pre.
    Suggest you try a Dynaco PAS 3 or 3x. Always a few on ebay going in the $125 to $200 range. Much cheaper way to test the proverbial waters.
    What Sunfire did you bag?
    More later,
    Tour...
    Vox Copuli
  • warviper
    warviper Posts: 585
    edited April 2004
    Think about getting the Sunfire Classic Preamp.
  • amulford
    edited April 2004
    No, Which Amp???
    I don't have any tube equipment myself, but I'm pretty sure that you can change tubes in almost any case. Just have to make sure it right type or design..
  • warviper
    warviper Posts: 585
    edited April 2004
    The sunfire mkII its 325 watts a channel.
  • Tour2ma
    edited April 2004
    I knew that...
    Memo to self: Work on short term memory exercises...
    More later,
    Tour...
    Vox Copuli
