Power Conditioners
ibewbrother
Hi All.... I was looking at some power conditioners while my system is in shut-down mode. My favorite right now is the Belkin Pureav pf60. It seems like it would do everything I would want it to do, what with assignable banks and delays and such. The only problem I see with it is the lack of RJ-45 jacks for the ethernet, It seems that the newer models have it, although I can't see them justify the added expense.....considering I'm probably going to use a switch to split my network.
So....Are these worth the cost? I saw several that would probably do what I want.... from $50 on up to $2000, with names like Adcom, Rotel, Paramax. Furman, and others. Are there any major differences between them, do I really need one (I'm positive it wouldn't hurt) , or are they all a variation of Snake Oil....
Any Thoughts appreciated.. as always..
Brother
Brother
"Making life enjoyable through expensive electronics." BillD
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
Carver TFM-45 (mains)
Carver A753x (center, surround)
320GB PS3, 42" Panasonic G10,
M60's as a Zone 2 off of the Pioneer in the living room
R.I.P. Onkyo TX-NR807
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
Post edited by ibewbrother on
I bought a APC H15 just to give me peace of mind. It has gone off a couple times when the power has gone off for a quick second or two and also helped with regulating voltage when it is either too high (hasnt happened) or when it drops (like when I use the vaccum).
One of the main differences between the models will be some have voltage regulation, some dont. They might have more or less assignable banks and better filters installed.
Personally the belkin is good, however I decided to spend the extra cash just for the voltage regulation aspect of the APC H15. Do I really need it? Not sure as I didnt notice any better picture quality or sound, but considering the price of all my gear, and knowing its being protected, I think its worth it.
P.S. I wish I had jumped on the APC S15 (which is the H15 + battery backup) from Vanns when I had the chance."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I have an APC15 and this Cyberpower device for power regeneration
http://www.cyberpowersystems.com/products/ups-systems/smart-app-ups/paragon-series/OL1500RMXL2U.html?selectedTabId=specifications&imageI=#tab-boxSpeakers: SDA-1C (most all the goodies)
I have the PF60 and like it, but I think the APC15 is likely a better unit.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Well.. after a bit of looking.... I went with the Belkin because I think it will look better with my set-up. Not very scientific, but as long as it gets the job done.
Thanks Much for the advice....
Happy Listening...
Brother"Making life enjoyable through expensive electronics." BillD
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
