Speaker placement
davehall83
Ok so please see drawing, Front's are RTI A7's or A9's havent decided, Rear's/sides are FXI A4's and Center is CSI A6. Sub is open for debate but something good to come and palce next to sofa or fireplace. I have boxed in where I will place speakers in realation to sofa. What do you think? I am hoping the FXI A4's bipole/dipole mode make up for the odd shaped room and where the sofa is placed but I want to make optimal placement of these speakers. Unfortunately center channel will have to mount above TV which will be about 5ft high but maybe tilt some down to shoot right at couch. Let me know if I am on track here, please note the surround's were a typo the are FXI A4's not RTI or whatever I put there.
Post edited by davehall83 on
Are you set with the TV location in the corner? You really should get your L C R placed around the TV in that order. L on the left side of TV, C over or under TV and R on the right side. That way sounds will be correctly placed with the action as you watch. If you could move the TV between the A9s with the A4s directly behind the sofa would be good. If the TV must stay in the corner and you can't get the center under/over and the right ch. on the right of it, a sound bar may be your best bet. Maybe others can give some better suggestions. That's a tough lay out
davehall83, it looks like that is your best option. Tough room.
apphd, the TV is not in the corner, that's the fireplace.Political Correctness'.........defined
