New Car - 2005 Subaru Forester XT
eloplayspolo
eloplayspolo Posts: 1,117
edited March 2012 in Car Audio & Electronics
Well guys, looks like i'm going to be moving from SoCal to New Hampshire:eek:
Looking at some 4wd cars and selling my civic right now...
looks like the winner will be a 2005 Subi Forester XT Limited.
Found one with 70k miles and they are asking for 13,000, im thinking i can get them down a bit and have some cash
to start a new install.
Gonna be fun. Im looking for some SR 5" comps, trying to figure out the Sub, the JL shallow mounts seem pretty
insane!
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Post edited by eloplayspolo on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited March 2012
    Dependable cars I'll tell you that much.
    Carfax available for the car? 13k seems a bit much IMO for Ca.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • eloplayspolo
    edited March 2012
    kawizx9r wrote: »
    yeah carfax checks out good, 1 owner.
    The car is price a little under book, im sure ill get a good deal, i paid wholesale for my civic, i haven't gotten a car for anything
    more than an amazing deal.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • codyc1ark
    codyc1ark Posts: 2,539
    edited March 2012
    kawizx9r wrote: »
    Subobs rock, I feel like that's a good price for an 05'.
    However in regards to a carfax, a lot of times it's not worth the paper it's printed on. We had a 2010 in 2010 ford focus that was bought with 3k miles on it in the shop, after an initial tear down it turned out that the car had had a uniside and quarter panel put on it, poorly. Had a clean carfax though... (dealer bought the vehicle back after we discovered that)
    http://caveatemptorblog.com/carfax-know-its-limits-auto-fraud-week/
    All I'm saying, is be aware, make sure you and a independent professional look the vehicle over when buying both a new and used car...
  • eloplayspolo
    edited March 2012
    I was told MANY roads in Vermont are not plowed and 4 wheel drive is a must. My girl has a rear wheel tacoma with the TRD package and a slight lift that im sure will be fine, but my civic is like 120hp and on low profile tires, doesn't seem safe to me....
    Yeah, carfax is definitely not the end all of used cars, but its still good to have. I always take my used cars to the factory and have them put it on the computer for 60 bucks before i purchase it.
    My father was a General Manager in the car business for 30 years so i have him looking over my shoulder.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • eloplayspolo
    edited March 2012
    So here is the potential Build...
    Comps: Polk SR 5250 (Bi-amp'd)
    Sub: Polk SR 12 DVC
    Amp 1: RUB4.600 - Soundstream 4 Ch. 600 Watt RMS Rubicon Series A/B
    Amp 2: RUB1.1000D - Soundstream Monoblock 1000 Watt RMS Rubicon
    Open to suggestions on the amps. PDX are tempting but the price is a little steep.
    My goal for the install is to look as factory as possible so everything will go in stock unless i install it and just hate it.
    I am looking to figure out a processor. MS-8, bit one... or IDK, im open.
    I am also thinking of a carputer, specs i don't know, i really haven't looked enough into them to determine what im after, just something with a factory look where i can have endless media as well as tether the wifi from my phone. I have always been a PC guy so i don't see that causing me problems, i already picked out the board and it has Optical Out.
    In order for me to change the factory stereo i actually need to Order a JDM part from overseas. Kind of a bummer because it costs around 430 dollars shipped... im really not happy about that.
    Give me some ideas and opinions please. Mac i know you aren't just running the SRs anymore, any suggestions?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • eloplayspolo
    edited March 2012
    Here is the car btw. Going to try and close the deal tomorrow.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • arun1963
    arun1963 Posts: 1,797
    edited March 2012
    Congrats in advance!!
    Don't go with the carputer,much better to go with a processor. If you're going to run a 2 way plus sub the bit10 is a perfect match. The Soundstream should be fine. You'll get 4x100 for the components and 800 to the sub wired at 2ohms. Thats plenty power.
    Even with the stock hu you can use the amps to run active. But the bit10 would add tons of processing options and allow you to really tweak the sound. Other than the processor you're set for equipment. Spend sometime figuring out where you want to install the drivers. Placement and dsp are the two most important parts of a sq setup. Get the placement right and things will be simpler to dial in.
    Once you get the car take some pics of the inside lets look at some placement options. You will also need to do some deadening to try and isolate the cabin and lower the noise floor a bit. If you install the mids in doors you will need to seal them. Mac is still using the SR5250 mb.
  • eloplayspolo
    edited March 2012
    ARUN! thanks for responding.
    Im going for 75 feet of RAAMmat BXT II and 70 feet of Ensolite IUO
    Yeah, i actually decided today to go for a Indash Nav, i think i might get the processor first though. That way i dont need to buy everything at once.
    im actually going for the larger sound stream amp for the sub. I am going with the 1.1600d
    Its 1100@2 and 1600@1, its 10 bucks more than the 800@2, so headroom will be worth it :)
    install locations: im 99% sure im going to keep it 100% stock looking. Here is the door pannel
    Sub will be done in a similar fashion to this...
    How is the MS-8 compared to the bit one?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • eloplayspolo
    edited March 2012
    2013 Toyota Prius
    Mosconi 6to8 v8
  • arun1963
    edited March 2012
    Ah, yes!! That is going to make the rabbit hole much deeper. 248 bands of eq at 1/24 octave:eek:. A perfect application for a rta. Flatten things out and then start. Two things though. First the ability to hear the subtle difference between changing 1, 1.04 and 1.08hz. Multiply this over 250 frequencies and you hit the brick wall of hopelessly lost at sea, on one of your expiditions.
    The second is the ability to think and remember differences at 1/24 oct. Hear something thats out of place and know that you have to look a 1/8 oct range and then go back and validate at 1/24oct. The funny thing is I wouldn't be surprised if its all doable.
    The 360.3 doesn't have a firm launch date yet. Like with the MS-8 there have been multiple dates that have been missed. Both units are a quantum jump in technology. It's almost a given that they will come with bugs. Plus you're going to struggle with the 248 bands if you haven't cut your teeth on 31 bands. If you're not planning to go 3 ways plus sub, a 5 ch processor will save you some $$. However yes, it will take away the flexibility of paying more but having the option for a 3 way down the road. That's a call you have to take.
    The sub and mid locations are fine. You want that sub enclosure to be around 1 cuft if you're going to go with 800 watts. With 1100 watts you'll have to watch both the enclosure and the gains on the amp:lol:. The SR tweets are ring radiators and hence a narrow field of dispersion. Having one on axis and the other off axis, is going to play havoc with the L/R FR. Try the tweets in different places. double sided tape is great :wink:. Try the tweets in the stock locations, on the dash, on the a pillars and see what works best for you. Try keeping them a bit more on axis.
    I'm not a fan of auto tune in a car so I would choose a bit1 over the MS8. Purely personal opinion.
  • eloplayspolo
    edited March 2012
    of course it will be buggy at first, but what software isn't (i work for a software company lol).
    The auto tune is supposed to be reallllllllllllly good as a starting point, at least that's what the few reviews i have read have said.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • eloplayspolo
    edited March 2012
    i was also thinking at some point i may wana go 3 way with dedicated mid bass in the rear doors.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • arun1963
    edited March 2012
    You don't need mids in the rear doors. You don't want speakers behind you period.
  • eloplayspolo
    edited March 2012
    So - The dealership i went to was a small little lot that specialized in rebuilt vehicles. I wasn't impressed. The guy was actually really nice, but they made no effort to detail the car before i came, it kind of pissed me off, i couldn't get an idea of what it would look like clean.
    So now, i checked around some more and a ford dealership by my house just listed a 2005, in a color i like more with the interior i like more, but its still not my first choice on exterior. My dad is going to call the GM and talk to him about the price and see how far in it they are.
    I also lowered the price of my civic a bit hoping it will sell faster.
    here is the car im looking at now....
    http://www.autotrader.com/fyc/vdp.jsp?ct=u&car_id=317624446&dealer_id=100003816&car_year=2005&systime=&doors=&model=SUBOUTBK&search_lang=en&start_year=2005&body_style=WAGON&keywordsfyc=&keywordsrep=&highlightFirstMakeModel=&search_type=used&distance=200&min_price=&rdm=1331453885240&drive=&marketZipError=false&advanced=y&fuel=&keywords_display=&sownerid=577056&lastBeginningStartYear=1981&end_year=2007&showZipError=n&make2=&certified=&engine=&dma=LOS_ANGELES_OC&feature7=leather+seats&page_location=findacar%3A%3Aispsearchform&body_code=0&isFlashPlugin=true&transmission=&default_sort=&max_mileage=75000&color=&address=92708&sort_type=priceDESC&max_price=16500&make=SUB&seller_type=b&num_records=25&cardist=2&standard=false
    we will see how it goes.
    2013 Toyota Prius
    Mosconi 6to8 v8
