Power Amp
over50
I just bought a used B&K power amp. My question is i have to set the volume on the back of the amp almost at maximum to hear any audio . Is this the normal?
Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Post edited by over50 on
You should set it to max, then run Audyssey again on your Onkyo. It should calibrate it to the proper levels on its own.
Agree Max, and rerun setup.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
yep, set it to max and adjust vol from the AVR or preamp.
Ok . it seems strange that i keep volume at max .Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
BDI Icon 9429 TV Stand -
Thanks for the reply. I leave volume at max and rerun AudysseyMarantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
I also have a 2 channel Sonance 2120 power amp. http://www.sonance.com/products/electronics/detail/231
Would you guys recommend just running the B&K and sell the Sonance or hook it up to power my surrounds. My first thought is just keep the 3 channel B&K and let the AVR power the rest. Any thought?Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Try it both ways and see what you like better. If it was me, I would let the avr handle surround duty and maybe sell the other amp to offset the cost of the B&K.HT SYSTEM-
lsi 9's -
I was thinking the same thing. I just posted the sonance on CL. Thanks for the repy tonyb. I also reran the Audyssey. The front stage sounds better .Thanks again .Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
