Denon POA-6600A monos and DAP-2500 Preamp
Texas42
I'm reluctantly selling my Denon POA-6600A mono-block amplifiers and Denon DAP-2500 Preamp. These were the top end of Denon's lineup and still are one of the best made set ups available. The amps were $3000 new by themselves and put out 265 Watts/ Channel into 8 OHMS 450 Watts/ Channel into 4 OHMS. They use Denon's Optical Class A topology and sound extremely clean and clear. The amps will run in either balanced or unbalanced configuration with the connections on the back and push of a button on the front. The Amps were upgraded by removing the stock attached power chords with IEC connections which allow the use of high end separate power chords. I will include some stock IEC power chords with the sale. Also, the amps come with a custom made set of 'AudioTux' amp covers ($200 option), that I will include at my asking price. These are custom hand made with real leather (not cheap vinyl) and marine grade plastic that does not warp or discolor. Truly a nice way to protect your amps when not in use.
The Denon DAP-2500 preamp I am selling is a tremendous full function (with remote)preamp with built in DAC (digital to analog converter). The preamp has a phono stage, tape loop, balanced and unbalanced outputs, etc...You get it all! The preamp and amps also have triggered relays and I will include the cables for that where you can turn on both the preamp and amps with one push of a button on the remote. So my price of $1050 is for both amps, preamp, remote, amp covers, remote trigger cables, and IEC power chords. I have boxes (although not original) for shipping if need be. I believe the Preamp was over $2000 new so basically selling over a $5000 set of gear for 80% off. Email if interested. Equipment is available for audition in my home in San Antonio, TX. The top of the preamp has a couple of scratches on it and one of the two amps has a couple of scratches. All gear is very presentable though with no functional issues. Email if interested.
Post edited by Texas42 on
Hello, are you 6600a's and preamp still available?
Sale Pending. I will know for certain by Friday, March 2nd.
Hope to own those someday, what do the THX covers look like?________________
2 Channel-Denon AVR-4520/SDA 2.3TL's
5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/ -
The Denon gear is now *SOLD*
If you are referring to the 'AudioTux' covers, they are hand made here in San Antonio by a lady with real leather and marine grade durable plastic that doesn't discolor or crack. They are custom made to fit your particular component. -
how do u buy these amps
You might start by reading the entire thread after which you would see they are sold.Political Correctness'.........defined
President of Club Polk -
