New to me RTA 11 with bad mid/woofer
Shacky
Just picked up a pair of RTA 11. One mid/woofer is frozen. Thought I could use one from my Monitor 4's but they are
different resistance. RTA 11 is 7.4 OHM and 4 is 3.6. Anybody have an extra?
Post edited by Shacky on
Welcome to CP,
If yours are MW6600 then this is a few months old but you might wanna give it a try.
http://www.polkaudio.com/forums/showthread.php?126409-5-Nice-Polk-orignal-MW-6600-drivers-for-SDA-RTA12b-and-Monitor-10Bs-early
Also on the 17th post in this link you'll find the original manual in pdf format if you don't already have it.
http://www.polkaudio.com/forums/showthread.php?47151-R.T.A.11-quot-s-%28I-found-the-paperwork!!%29&Monitor 7C's With Tubes -
Place an ad in our "Wanted To Buy" section.Political Correctness'.........defined
President of Club Polk -
Thanks so much. Will do.
Has anyone had luck fixing shifted magnet in these drivers? -
This is not the thread I was looking for. But check it out.
http://www.polkaudio.com/forums/showthread.php?87460-MW6510-shifted-magnet-repair&highlight=magnet%20shift--Gary--
Yes these have MW-6600 drivers.
