Budget Optical Audio Cable Recommendation
PreCd
PreCd Posts: 786
edited February 2012 in Electronics
I was given a Sony Bravia 5.1 surround sound system for my living room television and was wanting to use the optical cable hookup instead of the standard RCAs. A down and dirty system calls for a down and dirty cable. Can anyone recommend a budget optical audio cable they have purchased and are happy with?
SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp
Post edited by PreCd on
    tonyb Posts: 33,072
    I would just go buy the cheapest optical cable you could find at Wallyworld, Radio Shack. You wouldn't hear much of a difference on that Sony system with an upgraded cable anyway so don't waste the coin.
  • steveinaz
    steveinaz Posts: 19,545
    This is a well made, budget Toslink that I like: http://www.cablestogo.com/product.asp?cat_id=7022&sku=40390
    I've also used the "Sonic Wave" glass toslink, if you don't mind spending more. Velocity and Sonic Wave are made by the same people.
    heiney9 Posts: 25,446
    For that set-up coming out of the TV go Mono Price.
    Something like this would be more than enough with a TV and HTiB.
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10229&cs_id=1022904&p_id=6270&seq=1&format=2
    IMO, $20 for the CablesToGo cable is overkill for that rig.
    How long do you need? My link is for the 10' cable you can buy a shorter cable.
  • pyrocyborg
    pyrocyborg Posts: 524
    H9, I got this exact cable and it's great. I'm not sure if it's any better than the cheapos 1.50$ one (non premium from Monoprice) in term of sound quality [0 and 1... for such short range as 3-6 feet, you shouldn't lose anything], but sure the connectors are better and the cable is sturdy. However, the cable itself is... heavier than it's plastic counterpart, so that's kind of a drawback: If your cable is standing by itself (nothing to hang it except the connectors), it might fall. However, if it's supported by a shelf or anything else, it'll do it's job quite well.
    Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
    Receiver: Denon X3500H
  • WilliamM2
    WilliamM2 Posts: 4,807
    I'm using one on monoprice's standard opticals for a 25' run. It works perfectly.
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10229&cs_id=1022901&p_id=2668&seq=1&format=1#largeimage
    The sound from TV isn't all that anyways, don't overthink it.
  • steveinaz
    With toslink it's more about a good positive connection and decent build. I like the Sonic wave connectors as they have a positive click when inserted.
    Steve, that's a great cable. I had a Sonic Wave glass cable when I did Toslink from an old computer. I just think for his use, it's overkill even though $20 really isn't that much $$$. I use the same Mono-Price I linked to for my TV and it's a very sturdy attractive cable. Normally I wouldn't recommend something so remedial, but for this application and the HTiB system no need to spend a lot.
  • steveinaz
    Yep, for sure--in this setup a plain vanilla toslink is fine, just wanted to throw a little nicer offering out there.
  • PreCd
    PreCd Posts: 786
    That is about the price I was looking for. I will look around for a 5' cable.....that is about all I need. Actually too long! Not looking for much improvement but it would be nice to get the Dolby 5.1 working.
    Thanks.
    heiney9 wrote: »
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • PreCd
    PreCd Posts: 786
    Ordered the cable from Monoprice. Thanks everyone for chiming in.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • Falke401
    Falke401 Posts: 15
    Good call on monoprice. Great products and even better prices.
