Understanding how a Recevier powers speakers
specd_out
I was doing some thinking on how a/v receviers said to be 7.1 or like and claim that they do 110 watts per channel, but when all channels are driven its more like 40-60 rms. What is causing that drop. Is it too weak of a power supply or just inefficent amplifiers? Does the receviers amp make a lump of power and each channel pull what it needs. I am just having a hard time grasping how it can be rated at one thing while only one channel is driven but when more channels are driven its actually be much lower. It sound to me like the power supply isnt that great.
I recently removed my mains from my Pioneer Elite, but my center and surround is still powered off of my Elite. Did I free up enough "headroom" so to speak to power my center and surrounds at higher volumes then previous? I watch alot of blu-ray concerts and the Center channel gets used alot more then the mains. Now that mains have more juice then i could ever use, will I run the risk of clipping the center at high volumes? Does the rear surrounds (t-15) really place that much of a draw on the receiver?
I hate not having some kind of indicator of where my amp is in relation to its max output. My 1.0t has indictors that make it a little easier. Not that i trust them 100% but its a good ball park.
HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator
Post edited by specd_out on
Bingo!Political Correctness'.........defined
President of Club Polk -
Jesse's got you there!
What's that Pioneer weigh? I think less than 29 lbs? Let's compare your Pioneer AVR with a two channel vintage receiver from the early '80s that I own. The Pioneer SX-3900 weighs in at about 45 lbs. and only has 2 channels. It outputs a real 120 watts x 2 into 8 ohms. It has one rather "large" and heavy toroidal transformer and two large storage capacitors which account, I bet, for at least half of its weight.
The average 200 watt x 2 power amp probably has a minimum of 50-60,000 mfs of storage capacitance and a monster toroid or two as well, along with other members in the supporting cast.
Although weight and size is not the end all and be all of power. They are a factor in most A and A/B amps.
cnh
Not only that but that power is shared by 7 channels, audio and video processing in avrsHT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
ISF Level 2 Certified Calibrator -
That's right. There is, in most cases, no separate power supplies for all of that in most AVRs. So what a load of work you have a fairly light-weight unit performing.
The weight of any AVR tells you how it's made. Or what the watts are about, BS vs Real.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Weight of the unit is a big deal to me. My a753 Carver goes around 70lbs...and it's big. It also has a nice bank of HUGE output caps.(23000 micro farads...each?)"Making life enjoyable through expensive electronics." BillD
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
Carver TFM-45 (mains)
Carver A753x (center, surround)
320GB PS3, 42" Panasonic G10,
M60's as a Zone 2 off of the Pioneer in the living room
R.I.P. Onkyo TX-NR807 -
ibewbrother wrote: »Weight of the unit is a big deal to me. My a753 Carver goes around 70lbs...and it's big. It also has a nice bank of HUGE output caps.(23000 micro farads...each?)
You comparing a power amplifier to an AVR, why?
23000uF is a very large cap. However, lots of smaller caps are preferred because they are faster than large ones.
BTW, I believe your amplifier weighs closer to 40lbs.Political Correctness'.........defined
I think this is an audio engineering myth.
It only makes sense if the residual inductance (of the smaller capacitor) per uf is less than that
of the larger capacitor, which is usually not the case (at least when comparing capacitors of
the same construction type).
I assume we're not talking about something implausible like 1000 10uf film caps replacing one
10,000uf electrolytic here.
... and in fact, if you put many small capacitors close together on the board with the same orientation,
you can increase the residual inductance and make the array worse (slower) than the single bigger one.cristo
NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
(with Sonicraft/Solen/Mills crossover rebuild) -
I favor the class D amps, which weigh in alot less and sound great. A slightly different ball game than conventional amps.Shoot the jumper.....................BALLIN.............!!!!!
I think this is an audio engineering myth. .
I wouldn't go that far. There's more to it than size or number of caps. But if size is any indication, look at the bigger caps in older receivers and the smaller more numerouse ones in todays. Older receivers have rounded, somewhat flabby low bass while todays receivers can dish some well defined fast low end. Of coarse all that can't be contributed to caps alone but I'm pretty sure it helps.
Design has alot to do with it, god knows there has been excellent built pieces in the past that still sounded like garbage becouse of poor design, so on that aspect I can agree. Stranger crap has happened in this hobby for sure.HT SYSTEM-
lsi 9's -
+1 cristoHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
I think you're fine the way you have it. That AVR has plenty of power to run your remaining three speakers. You do have another pair of indicators - your ears. They'll bleed before you damage that center. JMHO, of course.I recently removed my mains from my Pioneer Elite, but my center and surround is still powered off of my Elite. Did I free up enough "headroom" so to speak to power my center and surrounds at higher volumes then previous? I watch alot of blu-ray concerts and the Center channel gets used alot more then the mains. Now that mains have more juice then i could ever use, will I run the risk of clipping the center at high volumes? Does the rear surrounds (t-15) really place that much of a draw on the receiver?
I hate not having some kind of indicator of where my amp is in relation to its max output. My 1.0t has indictors that make it a little easier. Not that i trust them 100% but its a good ball park. -
With a conventional Class A or AB amplifier design, you have to remember the laws of physics.
From my experience, a 62lb. AVR sounded much better than a lighter unit that is also Class A or AB.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
