Custome Speaker Wires - Sourcing Parts & Soldering
Drenis
I think this would be the best place to post this.
I'm putting the finishing touches on my desktop 2 channel setup and purchased the last two pieces last night. I was given some solid copper core wire in 12 awg. Somewhat stiff but it was free, never been used. I have enough length to make some DIY speaker cables and jumpers for my new set-up.
I'll be running two 3' lengths from the amp to the subwoofer and using speaker level input/outputs. then two 4' length pieces from the speaker outputs to my bookies on my desk. I'm looking to terminate one end with banana's and the other end with a pin style plug as the subwoofer uses the spring clip design terminals and probably wouldn't fit banana's. I'm not 100% certain. Maybe I can get away with it on each end. I was to wrap them in a tech-flex style sleeve and solder the terminals. I guess I'll need boots as well. I'll probably piggy back an extra bit (4") of length to bi-wire and replace the stock jumpers.
I've been wanting to get into soldering more as I have a passion for electronics. Never got to pursue that path and feel this would be a great exercise to tinker with. I have a soldering iron and some basic tools, have soldered quite a few times so I'm familiar with the basics. But I'd like to expand on that. So any recommendations with respect to soldering as well as tools of recommendation would be greatly appreciated (I currently just have a basic iron stick without any adjustments). Obviously that works but not for everything. Heat control is needed for starters.
I'm also looking for suggestions where I can find the banana's that can be soldered, boots or cable pants, and this tech-flex material. I really don't know where I can find/buy some.
Still need to find a good entry level USB cable of about 4' and a pair of IC's of about a foot... oh pepster? :razz:
Post edited by Drenis on
Well that's embarrassing... I can't even spell the title right... *fail*
For DIY speaker cable: http://www.bluejeanscable.com/store/speaker/index.htm
For nanners: http://soniccraft.com/products/connections/banana/vampire_b12.htm
Boots/Pants and tech flex can be found at: http://www.parts-express.com/wizards/searchResults.cfm?srchExt=Cat&srchCat=873 and http://www.parts-express.com/wizards/searchResults.cfm?srchExt=Mfg&srchMfg=299
USB cable: http://www.amazon.com/Belkin-F3U133V-06-GLD-6-Foot-Hi-Speed-Cable/dp/B000621N26/ref=sr_1_2?ie=UTF8&qid=1330127565&sr=8-2"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
A few days ago I was thinking about DIY speaker cables and happened to read this thread.Thank you for the links Face and have fun on your project Drenis!Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player -
Thecableco.com has a great selection of bulk cable.
I like the gls bananas locking at amazon.comSpeakers: SDA-1C (most all the goodies)
I used this Braided techflex: its Nylon so it doesn't stretch but it feels silky smooth. I haven't gotten time to install it on my jumpers (being in the hospital and all)"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
GLS are really nothing special, they're brass just like most cheap nanners."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ebay ebay ebay. Everything is cheaper on there when you add shipping in. I got techflex, cable pants, Adhesive lined 3:1 heatshrink, and nanner plug all cheaper then what it would cost to buy it all from parts express or other companys. I just made mine a few weeks ago. I bought my wire at lowes, its also cheaper there as well.HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator -
Drenis, Don't worry about temp control. way over-rated. I worked in a electronics factory when I got out of college, supervising about 40 women working at soldering stations. They used these grat big soldering irons on pretty small parts, just to heat up what needed to be soldered fast without transfering a lot of heat into the rest of the part and they could solder really fast. You don't need a really large one but something like this will work in most uses.
http://www.grainger.com/Grainger/WELLER-Soldering-Iron-5JH79?Pid=search
I seervice MRI and CT scanners and this is what I use for almost everything, including making my own speaker cables.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Wow... this was all perfect. All questions asked and some great sources.
Thanks peeps, Face, Zane. -
Chris V has higher end DIY components, as well as some very good DIY recipes for both speaker cables and IC's:
http://www.vhaudio.com/ I've built the braided Cat 5 cables as well as the Finesilver IC's - very nice!
www.takefiveaudio.com is a Canadian company that is good to deal with.
Good luck!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
$125?? Good iron but WAY too expensive. That one can be had on All-Spec for 85, just be sure to shop around. Think I saw that for 65 once on Ebay. Kinda overkill for basic soldering, IMO, but a solid iron nonetheless.TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
You really can't beat this solder station for most work.
I have tried a bunch in the past and this is my favorite hands down.
$99 and shipping is free (not sure about Canada).
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=372-145
When combined with one of these, you should be set for any soldering project.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?productId=100085564&storeId=10051&langId=-1&catalogId=10053&ci_sku=100085564&ci_kw={keyword}&cm_mmc=shopping-_-googleads-_-pla-_-100085564&ci_gpa=plaTesting
Testing
Testing -
No worries, I thought it was French! Custome!:cheesygrin:
I second pepster's Weller WES51 recommendation. I got mine for slightly less from Amazon.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Half of the battle with soldering is keeping your tip clean and "wetted." Wetted meaning you always want there to be a nice layer of solder over the tip. Adding solder to the tip (or "tinning" the tip) when the iron is not in use will help protect your tip from oxidation and make it last longer. Also soldering is much easier when the tip is clean and wetted because it helps with heat transfer.
Use a wet sponge to clean your tip when needed (you can do this when the iron is on). If your tip gets dirty to the point where you can no longer tin it (the solder won't stick to the tip), clean it with a brass pad - if you can find one. If not, you can also use a brass brush but do this lightly and only if absolutely neccessary because it is more abrasive and will cause the tip to wear out faster.
And using tin/lead solder will make things much easier than using the lead free stuff. Lead free solder has higher melting temperatures and will cause your tip to oxidize/become de-wetted fairly quickly. Lead solder flows better and just works better all around.
And flux is your friend.
