Quad subs
rubin
rubin Posts: 565
Would one sub out (rca) have enough signal strength to run 4 subwoofers?
Post edited by rubin on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited February 2012
    Each split should be a -3dB drop in signal strength. If you have a hot signal to begin with or enough gain on your sub amps to make up the difference, it could work. If you run out of adjustment on your sub channel on your receiver, you could always drop the gains on the other HT channels to gain back some level of control. If this doesn't work, then you will have to find a preamp/splitter to bring the levels back up.
    Try it and find out.....
  • Conradicles
    Conradicles Posts: 6,379
    wapanstore wrote: »
    I have built around 20 custom boxes for ram's and I think my best install for pure quality was a guys 02. He had two 10" directed audio (the same guys who make viper alarms)sxd410's.
