Pioneer Elite and Polk LSi's
falconcry72
falconcry72 Posts: 3,580
edited April 2012 in Electronics
How do the Pioneer Elite SC Series of receivers do running an all LSi setup? i.e., 15's, a C, and FX's.
I'm thinkin' about going LSi, so I'm trying to plan out the surrounding electronics. I know an external power amp is ideal, but can a SC-37 drive them well? Like really well?
Post edited by falconcry72 on
  • codyc1ark
    codyc1ark Posts: 2,533
    edited February 2012
    My 25 drove my 9's and center fine, however I didn't push it too much off of the avr. When I added my first amp, it was a huge improvement. I wouldn't be comfortable running a 5.0 4ohm setup off of my avr for any lengthy period, even if it is a hefty one...
  • nwohlford
    nwohlford Posts: 700
    There are some issues with the ICE amps that Pioneer used and 4 ohm speakers. At lower levels they should be fine, but probably no increase in power over 8 ohm speakers before clipping. The new series of SC receivers are thought to have addressed this issue.
  • falconcry72
    hmm... I was hoping to hear that the Elite SC's were more capable.
    I could drive them off (3) Adcom GFA-545's... they're only 100 WPC, but they handle low imp. loads with ease, and kick major butt.:cheesygrin:
    You should know, Neil, I bought a couple of'em off you.
    tonyb Posts: 33,065
    hmm... I was hoping to hear that the Elite SC's were more capable..
    They are capable, just not ideal. Look at it like this, would you power the Maggies off a receiver ? Give the LSI's the same thought if you want them to sound their best.
    heiney9 Posts: 25,396
    The 545's will run LSi's all day long provided you aren't at insane levels and have in a large room. I ran a single 545 for my 2 channel with LSi 9's and it never broke a sweat until you really listened loud.
  • PSOVLSK
    PSOVLSK Posts: 5,371
    heiney9 wrote: »
    Same experience for me, except I had the Adcom running R/L in my HT setup. My H/K 7300 (flagship model) was running pretty hot so I added the Adcom to give the H/K a break. I didn't really notice any improvement in sound quality, but it probably saved my avr from an early death.
  • falconcry72
    heiney9 wrote: »
    That's what I figured. I guess I'll just stick with my current Denon 3805 as pre and GFA-545's for power until I need to uprade to bluray.
    When I do go to the hi-def formats, are there any surround processors that do hdmi, 1080p, DTS-MA, and DDTHD better than an Elite SC for less money???
  • angelsfann02
    angelsfann02 Posts: 589
    The Adcom 545 is a very capable amp. Unless you plan to listen at insanely high levels, the 545 will handle a pair of lsi's. You could score an Adcom 5503 for 2 fronts and the center, and run the rears off your receiver...
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
  • mantis
    mantis Posts: 17,312
    Only very few AVR's do well with 4 ohm loads. THe Pioneer SC models can run 4 ohm loads pretty well. I'd prefer to have a external power amp to drive all my 4 ohm channels.
    Standard practice when purchasing 4 ohm load speakers should automatically steer you into separates. No reason to strain a AVR into running at peak and sounding strained. IF an AVR is your game then 6-8 ohm load speakers should follow.
    NAD , Rotel , Cambridge are a few that run 4 ohm loads well and don't sound like they are at the end of their abilities. Yamaha , Denon , Pioneer , Onkyo , Marantz , Sony , Etc all have limits and don't allow your 4 ohm load speakers to perform their best.
    Lsi's are power hungry and why buy them if your not going to power them correctly.
    Dan
  • falconcry72
    mantis wrote: »
    ...why buy them if your not going to power them correctly.
    I guess I just have an affinity for watching Polk speakers writhe in pain...
    In all seriousness, though, I do want to power them properly; that's kind of, like, the reason that this thread exists.
  • syntheticzero
    syntheticzero Posts: 15
    edited April 2012
    I just purchased an NAD integrated amp for my Lsi9's --- the C 326BEE, around $550 (I don't fully understand why integrated amps are all so much cheaper than power amps, but whatever). It is fully stable for 2 channels of 4 ohm loads, and it sounds absolutely beautiful (I listened to them with some small B&W speakers at the store, and it sounded fabulous --- it sounds very good with my Lsi9's as well). I had been running my Lsi9's off of an old Onkyo TX-NR806 receiver, which worked at first, but after a couple of years it started to act erratically, first cutting out randomly and eventually the HDMI switching circuitry started to simply fail. Needless to say I wasn't that impressed with Onkyo reliability.
    So, I had to replace my receiver. Initially my plan was to run the NAD and get a relatively inexpensive receiver to drive the 8 ohm rears and subwoofer... however, there really aren't any inexpensive receivers with preouts anymore. Yamaha used to provide full 7.2 preouts in the old RX-V667, but the new RX-V771 no longer has preouts (GRR!). However, the Yamaha RX-A810 DOES have full 7.2 preouts, and so does the RX-A1010, which I managed to get at the super low price of $699 from a discounter (I think he was really trying to make a sale, because that's about $300 less than the going price I've seen elsewhere).
    The manual says the RX-A1010 can drive 4 ohm speakers. However you're supposed to put it in "6 ohm mode" and I doubt it will really work any better than the Onkyo did. So, my total outlay for all this is now around $1300... (it would have been closer to $1600 if I hadn't gotten the killer deal from the discounter). But, it does sound absolutely terrific. I had been considering an Emotiva XPA-3 but it looks so large and really I didn't need anything quite that stupendous --- the NAD is really plenty of amp for my needs. It's an integrated amp but I'm really just using it as a dumb power amp --- I just leave the volume at a fixed position and run the preouts from the Yamaha into the NAD on one channel. The only thing I do with the NAD is turn it on and off (thank god for Logitech remote controls or my whole setup would be a royal pain to use).
    The Yamaha RX-A1010 definitely does a better job than my old Onkyo did with all the processing. It really handles surround well. I think maybe if I end up adding a center and upgrading my surrounds to Lsi's I might try and see if the Onkyo can drive those while I keep the NAD driving my two fronts.
  • zane77
    zane77 Posts: 1,696
    edited April 2012
    I have on Onkyo PR-sc5508, it has all the features you are looking for, but i haven't heard any of the Elite AVR's to compare it to.
    Two Channel
