noises from blu-ray player
leftwinger57
leftwinger57 Posts: 2,917
edited February 2012 in Electronics
Hi Guys,I really do not watch bought movies all that much but since I had the avr and tv I went out and bought an open box Tosiba Blu-Ray bdx 2200w/remote.I made them h/u the unit in the store and it worked fine. Getting home I install it into my system and during the loading process and the annoying repitious trailer director thing out comes only what I can decribe as minor grinding noises.During actual play it's dead quite and the movie does it's thing w/ total effect.Question is this just a cheap open box $57 unit or do other blu/rays make this loading sound.One other thing that I've noticed is that loading takes quite a long time compared to my Denon cdp/dvd.Surround sound is fine and the depth charge scene in U-571 was room shaking just for an example.
  • chumlie
    chumlie Posts: 8,658
    I have a LG bd590 sounds terrible when starting but plays fine. So your not alone.
  • Glowrdr
    Glowrdr Posts: 1,103
    The slowness is a blu-ray thing. Just about any review you find on them will list the load times because it is significant compared to everything else we are used to.
    As far as the noise - it's just the laser tracking that you're hearing. No big deal as Chum said.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
    tonyb Posts: 33,065
    That loading noise is fairly common on cheaper BDP"s. Why do you think they sell for little coin ? If you can live with that noise, don't worry about it, if not, bring it back.
  • devani
    devani Posts: 1,497
    if you can ignore it, yea for whatever you paid....it's worth it....is that noise worth $100 more to you?
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • woodhead 2
    woodhead 2 Posts: 367
    I have a Samsung, and a Sony. They both do that.
    Panny 8000 project
    Oppo 103D
    Fronts- Monitor 70's
    Upper fronts- Monitor 30's
    Surrounds- Monitor 50's
    Backs- Monitor 40's
    Center-CS 350
    Sub- SVS PB 2000
    Onkyo 607[back up]
  • SDA1C
    SDA1C Posts: 2,072
    Personally...I would throw it in the street if it were too loud. By too loud I mean hear it at all. Normal? Yes on cheap players but none the less one of my biggest pet peeves.
    Too much **** to list....
  • Glowrdr
    SDA1C wrote: »
    Normal? Yes on cheap players but none on my Oppo.
    Fixed - I knew what you wanted to say :cheesygrin:
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
