Sda 2 polk spkrs serie 20825 .
PW47
INEED THE CABLES FOR IT THE BOTH CABLES THE BLADE AND PIN ? AND ILIKE TO KNOW HOW THOSES CABLES WORKS AT THE SDA 2 ? IKNOW THE ORIG CABLES IS OUT . SO SIMILAR JUST WILL BE VERY FINE . INEED TO PUT THOSES BEAUTYS TO WORK . FOR MY ACURUS . THANKS :loneranger:
Post edited by PW47 on
umm... SPAM?2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
Bad English on a good drunk, most likely.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
First of all, just WOW.
The dimensional drivers don't work if the cable is not installed. Which means, your using 2 of the 4 mid drivers. The dimensional drivers are what makes SDA's (Stereo Dimensional Array) SDA's. With out them working, the speakers aren't being used as they were intended.
Polk doesn't make the pin/blade cables anymore but what you can do as a temporary fix is put some speaker wire in the "pin" hole on both speakers and make sure it's snug (maybe some 14awg?). Make sure it's snug. The blade doesn't do anything but hold the pin in place so don't worry about that.
