pcb standoffs?
soundfreak1
Anyone know where i can buy standoff for pcb's?
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
I'm too slow....a sample....various lengths available.
http://search.digikey.com/us/en/cat/hardware-fasteners-accessories/board-spacers-standoffs/2098158?k=1896Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
mouser electronicsMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Thanks i just cked them out and looks like they have eberything i need. thanks again.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
What size do you need? I have a hand full or so from the TPA dac kits I've built. PM me.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
You can find metal and nylon standoffs of various lengths, threaded, non-threaded, or 1-side screw, at Home depot, lowes, ace etc. Might be quite a bit cheaper than ordering since shipping is probably a lot more than the parts unless you need lots of them. You could also use small blocks of wood or dowels and it would cost nothing if you have scraps around. I made some out of some UHMW stock I had around and they worked well.
