pcb standoffs?
soundfreak1
soundfreak1 Posts: 3,414
edited February 2012 in DIY, Mods & Tweaks
Anyone know where i can buy standoff for pcb's?
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
    SCompRacer Posts: 9,121
  • brgman
    brgman Posts: 2,859
    mouser electronics
    I’M OFFENDED!!!!
  • soundfreak1
    Thanks i just cked them out and looks like they have eberything i need. thanks again.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • bikerboy
    bikerboy Posts: 1,234
    What size do you need? I have a hand full or so from the TPA dac kits I've built. PM me.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • Bubinga99
    Bubinga99 Posts: 283
    You can find metal and nylon standoffs of various lengths, threaded, non-threaded, or 1-side screw, at Home depot, lowes, ace etc. Might be quite a bit cheaper than ordering since shipping is probably a lot more than the parts unless you need lots of them. You could also use small blocks of wood or dowels and it would cost nothing if you have scraps around. I made some out of some UHMW stock I had around and they worked well.
