Important: Please Read! - Proper usage of outputs and Y connectors
Serendipity
Serendipity Posts: 6,975
edited February 2012 in The Clubhouse
I am posting this in the Clubhouse because I have seen various confusion about outputs and Y-connectors and feel that this post could save you from destroying your gear:
Outputs are low impedance and MUST only be connected to high impedance inputs.
Never connect two outputs together, whether it be via a Y-cord, by connecting two preamp outputs together, or by connecting two amplifiers to a single speaker.
I have seen various posts about connecting outputs together, such as to "combine" the left and right outputs of a component to feed a sub, or to use two preamps with a single amp. I have also personally seen an iPod with a 1/8" to RCA cable connected to a Y-cord summing the Left and Right channels together to feed a mono mixing console. A Y-cord cannot be used to sum two signals together by itself!
Please, for the sake of your gear, don't do this! Hope this helps.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • Tankman
    Tankman Posts: 419
    ^^^^^^+1.I have a feeling that some people have done this with AVR's and Pre-amp's too use one sub with two outputs.I have been seeing a lot of powered subs with blown amps.This will do it.Great post!Newbee's take note of the post above.
    Toolfan66 Posts: 18,050
    I have been using a Y off my AVR to run 2 subs for 3 years with no problems..
  • Serendipity
    Toolfan66 wrote: »
    That is fine, and not a problem. Summing the L/R signals together is.
    You are splitting the signal to run 2 subs from the LFE output.
  • Tankman
    Tankman Posts: 419
    True,but i have seen some people who use say a AVR and a say Pre-amp run a sub cable from the sub out from both units to a Y and then to one sub.You can get the negetive feed back from the sub back too the amp or AVR that is off.Not good.
  • Serendipity
    ^^ yeah, don't do that.
    The unit that is off will present a load to the other unit's outputs and result in diminished sound quality.
  • obieone
    obieone Posts: 5,077
    In other words...:razz:
    <iframe width="560" height="315" src="http://www.youtube.com/embed/jyaLZHiJJnE&quot; frameborder="0" allowfullscreen></iframe>
  • Serendipity
    From my experience, it is better to just go from your receiver or pre/pro's LFE out to the sub and then use a "2 channel bypass" setting for music listening. In Pure Audio mode, the sub is bypassed unless you select stereo mode.
    Personally wish more HT receivers and pre/pros had 2 channel bypass with setup flexibility, so you can route the bass to the main speakers (true 2 channel) and not need to purchase a separate preamp. I like pre/pros because of their ability to integrate with many other devices in a system.
    With so much talk about HT bypass I would prefer 2 channel bypass (i.e. Pure Audio = Straight with no sub) with Zone 2 capability. Not many units have this due to the single DAC chip and therefore, may encourage misuse of Y connectors.
