Squeezebox connection upgrade
brgman
I am adding a new HD to my computer and was looking at sound cards.I currently have an ethernet connection from my Cisco Network to the squeezebox and wanted to know if i installed a ASUS sound card with SPDIF would i be better off running a coax line from the pc to the SB Touch or would it not matter much for sound quality?
Not interested in wifi for the SB.Too many wifi things pulling at it already so i prefer a solid connection.
Suggestions please?:question:
I’M OFFENDED!!!!
I’M OFFENDED!!!!
Post edited by brgman on
I think your only choices are wifi or ethernet. The SB does not have audio inputs - only RCA and optical outputs. Otherwise, I'm confused about what you're trying to do...?
You'll have to go ethernet.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Soundcards are generally a bad choice for the best transfer of music. What on earth are you trying to do? Go Ethernet or wireless, there is no other choice.
Damn I should have woke up more before asking
I forgot the coax is an output
never mind......Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Try the wireless, you'd be surprised how much you can run on it. If not, then your only alternative is ethernet for a hard wired input.
