Turntable Suggestions
newbie308
I am currently running a Technics SL1200 turntable with the stock tone arm and Cardas wires. I like the simplicity of the direct drive and the ability to swap cartridges with the p-mount for different records, but I'm tired of running to the turntable at the end of every record to prevent the thump thump thump of the needle. I'd like to replace the SL1200 with a similar unit with an automatic lift feature. What do you suggest?
Post edited by newbie308 on
I forgot to mention that I'd like to keep it under $1000.Enjoying the journey while never attaining the destination.
I do not know of any decent modern turntable with auto return. There are a lot of old 70s TT on ebay with auto return but will be a step down IMO. Keep your eyes open for a accessory that would mount to any TT and auto lift the tonearm at the end of the record. Probably not cheap if you find one but would be a better option.Speakers: SDA-1C (most all the goodies)
Here you go http://www.youtube.com/watch?v=UeQYPlFSNYsSpeakers: SDA-1C (most all the goodies)
I found the guy on ebay that sells the levitator. $95.
FOr a grand you could pull off a lot of very nice tables and cart. Add the levitator and your set.
Much better off than going to a 70s TT with auto return.Speakers: SDA-1C (most all the goodies)
The yamaha px-3
You would have to spend over a grand to get anything better.
http://www.youtube.com/watch?v=gJhY46LyogI&feature=related
You can find these on ebay $250 to $600
I can second that. I love mine. It was new in the box for 400 bucks, and I have it paired up with a Sumiko BPS EvoIII. I don't think I could do better for less than 3k.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Thorens TD-145
Got a link for him ? My search on ebay didn't turn up anything.:sad: -
Try this....looks like he wants contact via email.
http://wiplastics.com/page05.htmlSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Thanks.
A lot of good turntables were made in the 70's like Dual with auto return and a kitchen sink.
Sure, you can buy fancier looking tables but there are good vintage tables out there.
After all, that's what we had to work with, turntables.
I've owned a couple of AR turntables and some auto brands too. -
The Thorens TD-145 is an end of play- lift arm type, no return mechanism. Otherwise, it's identical to the famous TD-160.
http://www.ebay.com/itm/Yamaha-PX2-Linear-Tracking-Turntable-W-Ortofon-Kontrapunkt-B-/140701941244?pt=Vintage_Electronics_R2&hash=item20c27d3dfc
The PX-2 trumps the pX-3, but not by much. This one appears to be an outstanding table.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Some more at different price points:
http://www.audioadvisor.com/prodinfo.asp?number=THTD158
http://www.audioadvisor.com/prodinfo.asp?number=THTD1902
http://www.audioadvisor.com/prodinfo.asp?number=THTD235
http://www.audioadvisor.com/prodinfo.asp?number=THTD295Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Wow! Great suggestions guys!Thanks!
I'm going to try the Levitator first, but I realy like that linear tracking TT! I have had a few Thorens turn tables, but I prefer the simplicity of the direct drive and the adjustability of the tone arm on the sl1200.Enjoying the journey while never attaining the destination. -
I had a Thorens TD 145MKII at one time. In fact, I still have it. It sits on a shelf in my basement. I hope you have a nice solid place to put it. Sprung TT's are prone to footfalls, etc.
Besides, how many great modern TT's have you seen that are automatics. NONE. You were doing well with the SL-1200. A good turntable. Mod it and you'll have a great TT.#1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
#2 Cayin A-50T /Hornshoppe Horns/Squeeze Box Touch/Simaudio Moon 100D DAC/Rythmic F12 Servo Sub -
The PX-2/3 and other linear trackers are mostly direct drive units as well, and with regards to adjustability, they also have fewer needed adjustments because they track the record in the same way the record was mastered to begin with. The only adjustment needed for my table was making sure the table was level, the cartridge properly installed, and that the tracking force was correct.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
