Denon DCD-620...
Richd82
Richd82 Posts: 64
edited February 2012 in Electronics
any good? I found someone selling it for $40. Currently my only cdp is my ps3.
This is all i could find online about it http://www.ebay.com/itm/160730730069?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I would like this http://www.ebay.com/itm/STUNNING-Jolida-601a-Tube-Reference-CD-Player-/300626153617?_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D2%26po%3DLVI%26ps%3D63%26clkid%3D6302096542455347682 but its outta my price range for the foreseeable future.
Post edited by Richd82 on
  • chumlie
    chumlie Posts: 8,658
    For $40. I would give it a try.
  • nwohlford
    nwohlford Posts: 700
    I would hold off. I have had a DCD-820 since new, and it is a nice transport. Since the DCD-620 does not have a digital out, I assume that you are using the analog out. The DACs in those units are not supposed to be anything special. They are nice players, but I think for slightly more you can find something much nicer.
    Agreed ^^
  • Richd82
    Richd82 Posts: 64
    So what should i look for in a good cdp? What key features/specs should i keep an eye out for while finding a used piece?
  • headrott
    headrott Posts: 5,496
    Look for a DCD-3000. It's one of the best sounding "older" players I've heard. Should be able to get one cheap now as it came out in about 1992. It will blow away the DCD-620.
    Here is a link to one, but you should be able to find one cheaper if you look. This one looks to be in very nice shape though: http://www.ebay.com/itm/DENON-DCD-3000-AUDIOPHILE-CD-PLAYER-COMPLETE-BOX-ABSOLUTELY-MINT-CONDITION-/260955800256?pt=LH_DefaultDomain_0&hash=item3cc22d82c0
    Greg
  • nwohlford
    The DCD-3000 is a very nice CD player. One real advantage to it is that it has digital inputs, so if the laser or any other component ever dies you get a cheaper CD player with digital output and still use the DCD-3000 DACs. Probably tough to get one for under $300, though. Some of the other four digit Denons have very good reputations and go for a little cheaper (say down to $100).
    I would look for something with digital outputs incase you want to use an external DAC at some point. If you looking for older models, I would definitely read about them online, since players may have had laser issues or other issues which could make you player not last very long. I like Denon, NAD, and Marantz, but there a lots of good CD players from other companies (Sony ES and Yamaha to name a few others of the major brands).
    Also, I would include DVD players both the early generation TOTL 2 channel models (some of which had incredible 2 channel analog performance) and some of the more basic universal players which are great for their price. Some people overlook the 2 channel audio performance of some early DVD players, so they go fairly cheap on the used market (especially ones without progressive scan).
    Right now I am kind of combining the two in my two channel system. I have a modified Denon DVD-5000 that only plays CDs (intentionally unlike a lot of the DVD-5000s that had DVD laser issues) and a DVD-2910. The Denon DVD-5000 has the digital input like the DCD-3000 (it does not have balanced output though). I use both to play discs but only use the DACs in the DVD-5000. This way if the laser ever gives out in the DVD-5000, I still have the DVD-2910. (Although I just got an Oppo BDP-83 which I may switch for the 2910.)
