How to hook up Monitor 60's to a Pioneer VSX 921?
word2yamutha
word2yamutha Posts: 3
Im a newbie at installing a home theater system and I'm confused about the the 2 inputs on the speakers. Im not sure how to hook it up to my receiver. As of right now these speakers are front but I only see 4 connections to them. Sorry for sounding like such a **** haha. Thanks
Post edited by word2yamutha on
    edited February 2012
    Hook up to either the top or bottom set of posts, just make sure that the metal strap stays there connecting both sets of posts.
  • word2yamutha
    ok I have a dumb question, but what is the point of having two sets of posts?
  • chumlie
    chumlie Posts: 8,658
    In case you want to bywire or byamp them. Top post goes to the hi end, bottom to the low end. So if you take the straps out, that will seperate them. Not recomended in yout case, do as tonyb says and your good to go.
  • word2yamutha
    thanks for the help guys. It doesnt seem like there getting enough power from my receiver though. I figure each speaker is getting 110watts, correct? I originally wasnt going to buy this receiver or these speakers at first but it was a deal I couldnt pass up. I bought the speakers new 150 pair and the receiver was 200. They lack bass but I eventually well get a subwoofer.
    Make sure the fronts are set to full range, or large, in the receiver settings since you don't have a sub yet.
  • Waynesize
    Waynesize Posts: 62
    I have M60s hooked up to a VSX-821. Fronts set to "large" and sub set to "no". Lacked bass at first, but as they get broken in, the bass gets better. Give them some time to loosen up and they will sound better. Now, if I can just be patient and wait for the DSW PRO 550 to go on sale again:cheesygrin:
    Monitor 60 SeriesII
    Pioneer VSX-821
    DSW PRO 550wi
    Squeezebox Touch
  • bansheesho
    bansheesho Posts: 227
    Keep an eye on newegg.com for the sub... I really like my 660wi, it hits really hard and makes movies incredible during explosions and stuff..
    If you don't know about it, check out camelegg.com to get price history on the products to make sure you are getting the best deal you can...
    660wi
    http://camelegg.com/product/N82E16882290227
    550wi
    http://camelegg.com/product/N82E16882290226
    Newegg has pretty good prices on both if you are patient.
    Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
