Parasound HALO pre with non-Parasound amp?
Serendipity
Serendipity Posts: 6,975
edited February 2012 in 2 Channel Audio
Listened to a JC2 with a Bryston amp on Revel speakers. Wow, let me take back everything I said about Parasound HALO being too bright. With the right amp, that JC2 sounded really good. Not nearly as harsh or grainy on the top end as a Parasound HALO C2 with the A21 amp. The last time I heard the C2 it was paired with the Parasound A21 amp and it was bright even on PSB speakers.
So I am looking at a HALO C1 again, this time with an Outlaw Model 7500 amp.
http://www.parasound.com/vintage/c1.php
http://www.outlawaudio.com/products/7500.html
I have not heard the Outlaw 7500. For those who have (Sheardp, Grimster, etc.) how does it sound??
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
    tonyb Posts: 33,065
    I've had an ear on some outlaw amps, not that particular one though. The Bryston will run rings around it simply put. Outlaw was good around here for HT, but musically left some room for improvement.
  • Serendipity
    Thanks. The Bryston I heard was a pro amp. Not sure if that matters...
    Also, is there no issue running an amp like the Outlaw in 2 channels all the time?
    I understand the Outlaw is a 5ch amp. But I only have two speakers. So I will probably use the other channels for Zone 2, leaving the Center unused.
    heiney9 Posts: 25,396
    It's a slight step up (or rather sideways) from Emotiva as in it's not quite as harsh and in your face, but frankly it's nothing special.
  • Serendipity
    heiney9 wrote: »
    It's a slight step up from Emotiva as in it's not quite as harsh and in your face, but frankly it's nothing special.
    Thank you. I will look elsewhere.
