Ideal Desktop Amp
zingo
I need help finding the perfect desktop amp for my Father-in-Law. I haven't been able to find it yet, so here are the requirements and I'm sure someone will know where it is. It can be either tube or SS integrated, does not matter. Must have:
-Good headphone section
-Speaker out (binding posts)
-Attenuated preout (Stereo RCA)
Thanks for the help!
Post edited by zingo on
Try NuForce. They have a nice line of desktop-type solutions and are known for excellent quality products.
http://www.nuforce.com/ -
NuForce and Maverick Audio.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
mdaudioguy wrote: »Are there amps specifically for desktops, or are you just looking for something compact?
Compact would be nice, but "desktop" because it will be used as the power for PC speakers/headphones. -
I just noticed the Audioengine N22 which meets the requirements also; no idea about sound quality...
If you don't mind about something a little bit "bigger", a budget integrated amp could be great too. It's not compact by any means, but take the NAD 316BEE for example. It's smaller than the 326, but I don't know what you mean about the attenuated preout...Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
Receiver: Denon X3500H -
I thought parasound made a nice little unit? I dont remember the model..
parasound's is the Zamp.
the audioengine desktop amp gets some good press as well.Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
I love the Audioengine N22, Jake. Been using it in my office rig for quite a while, extremely quiet, output is a little bit airy via the Audioengine AP4's. And I'm using Kingwa NFB-3 DAC with it.Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
I had two audioengine n22 it is a very capable little amp, paired with the ap4 it is a great desktop system. I sold a combo for 300 and liked the amp so much that i kept one as backup.
You cannot go wrong there, check www.audioengineusa.com
Good luckHT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES -
Good luck
My goodness, whoever bought that set from you, that was a STEAL, especially with the AW1 included!!! I'm using the AW2 for my iPod Touch :biggrin:Gears shared to both living room & bedroom:
Living room:
Bedroom:
Other rooms:
It seems like the Peachtree Nova might be a great option for this with tubed pre, although not cheap...
Yes it was, i kept it exclusive for the guys on the forum but after about 45 days and no bytes mi sister bought it as a christmass present for my nephewHT:
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
