Dual mono amp drive SDA 2b without IC
huy
Dear PolkAudio members,
Anyone can help me to clarify this question:
I have a non common ground amp. Can I use this amp to drive SDA 2b without using Interconnect cable?
Thank you.
Thank you.
Post edited by huy on
Yes, you can use non-common ground amps without an IC, or you can get an AI-1 IC, if your speakers are compatible with that IC. The AI-1 is designed to be used with non-common ground amps and certain models of SDAs. Unfortunately, I don't have the list of what speakers are compatible with the AI-1 IC, but it would be strongly recommended that you use the AI-1 if your speakers are compatible. Otherwise, you lose the SDA effect, which is what makes these speakers so great.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
You can but they won't sound like they should and actually pretty bland. You are better off getting a common ground amp and using the interconnect.
What amp are you using? Did you check the negative post to see if it is a CG or not? I've got a pararsound that is a dual mono design with SDA2As using the interconnect. I called parasound to make sure the amp could handle it. You could also build the AI-1 interconnect cable to use with non CG amps. Best of luck, and welcome to club polk
-Ted -
If your speakers are compatible you can buy Lasareath's factory original AI-1 here: http://www.polkaudio.com/forums/showthread.php?128947-Polk-Audio-AI-1-Cable-Use-Mono-Blocks-with-your-SRS-s
Or go here and learn how to make your own: http://www.polkaudio.com/forums/showthread.php?74472-The-AI-1-Dreadnought-Project-Pt.1
Good Luck!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Thank all of you very much. I am using Power Amp 2 from Proceed. Proceed confirmed non common ground and negative terminal cannot tied together. My SDA set is Pin/Blade and serial number is higher than 14115. I am learning to do AI-1 interface.
Thank you for your help.
