Bass traps for corners?
musky1963
musky1963 Posts: 275
edited January 2012 in DIY, Mods & Tweaks
I am looking for some diy trap ideas, for the corners(triangle shaped. I am pretty limited on how large and want something that blends well into the corners, next to the 2.3tl's. What is a readily available insulation to get on the cheaper side. OC703? I guess you can say that I am advanced in woodworking as I am a furniture maker and carpenter, which should make it simple for me to construct them. I just want to get rid of the boominess that sometimes happens. Any proven corner traps that aren't imposing?
Jeff
Post edited by musky1963 on
  • thsmith
    thsmith Posts: 6,082
    edited January 2012
  • quadzilla
    quadzilla Posts: 1,543
    edited January 2012
    Someone correct me if I'm wrong, but in the reading about bass traps, and acoustic traps in general, the information I have is that the more dense the material, the less effective it is as an acoustic trap. So 703 would be more effective than 705. But again, this comes from the net, so I don't know how accurate it is.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2012
    You are correct in your thinking for a given size. The harder stuff has a lower absorption more than the softer stuff and needs more to do the same job.
    Here is a great site for coefficients. Absorption Coefficients
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited January 2012
    When I first started checking into corner traps ,seems like people were cutting the OC panels into triangles and stacking them to the ceiling. Then others decided that the OC pink fluffy stuff worked better as Joe mentioned above. Also I've noticed some trap companies make corner traps that allow a certain amount of air space between the trap media and sheetrock or whatever the wall is made of. Maybe someone here has tried all 3 methods out and can chime in on what worked best.
  • FTGV
    FTGV Posts: 3,650
    edited January 2012
    Polkie2009 wrote: »
    I did the triangle approach but on a smaller scale .Unfortunately they are not big enough to be very effective below 150hz -ish or so.
    http://www.polkaudio.com/forums/showthread.php?84121-Simple-corner-traps.&highlight=diy+corner+traps
    To be effective to very low frequencies requires lots of material in both density(thickness) and surface area.IMO the large corner chunk approach (layered triangles) floor to cieling would be the most effective for the Diy'er but like I encountered WAF issues may rear their ugly head..
  • Joe08867
    edited January 2012
    Have not tried the triangle but have tried completely stuffed and airspace between trap and wall.
    It really depends on the room. Mine was a basement remodel that added a small recording studio room for my band at the time. The traps I used were 8' high about 2' wide or 1/2 a sheet of plywood wide.
    I used a trap on opposing corners of the room 25x35 facing each other so to speak. The one near my drum set was the one I tried both ways. Airspace gap helped calm some of the boom and warble you can get from guitar and bass amps but it left a lot of errant bass notes floating. No good for recording so we tried it filled and it seemed to be almost as good as the airspace for trapping boom but it almost eliminated the errant bass in the air. Sorry I don't know how to explain this stuff in a professional way but I hope you get the jist of my post.
    We used the light and fluffy stuff. Tried 703 in the studio and it didn't work. I have used it for my HT setup in my old house 17x20 room and it worked quite well but not for very higher pressure levels. It just couldn't absorb enough sound. It could probably have used to be bigger but the room and aesthetics WAF limited the size we used. The HT living room one was 7' by 1' wide.
