Looking for a "Cool Running" Receiver
Gulfstrings
Want to upgrade our bedroom system (no HDMI currently) with a lower priced receiver. Like the Onkyo 509, but the space will be tight - components are stacked, and I believe the Onkyo may run too hot.
The current receiver is a Sony and it seems to tolerate the close quarters well. Sony offers a model (810 or 820) that's pretty close to what's there now and to the $200 - $250 I want to pay, but would like to look around a bit.
Hoping you all may know of a few cool running receivers ... ?
Marantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Technics SL-1301/Shure M97xE
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Post edited by Gulfstrings on
Sunfire but it might be out of your price range.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Pioneer 1021.Shoot the jumper.....................BALLIN.............!!!!!
Used SC-05/07. Ice power to the rescue!
Oh, just saw the budget, you'll have to search long and hard for that order at your price range. I had a onkyo 607, and it seemed to run warm. Although I don't know about current models. Good luck! -
One reason your current Sony runs cool is because it doesn't have HDMI (no video processing going on). A lot of the heat generated in modern receivers (Onkyo for sure, but all to some extent) is from the video processing chip. I will admit that in my experience (very limited with lower-priced receivers), the Sony and Denon's do seem to run cooler BUT you will pick up some added heat with video processing of HDMI. You might want to go to a Best Buy or similar where several models are and just walk through and lay your hand on top of several brands. That should give you some idea.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I have a marantz nr1501 and it is pretty nice. I found mine used on cl for $150 & it's only 4" tall with 4 hdmi 50wx7. eBay I think they are a little over $250
I'm giving up on this project. The initial interest arose when I replaced our Pioneer BDP-320 with the new Oppo. I wanted to "utilize" the more expensive Pio in the bedroom and slip the value Sony BDP under the bed. But (as they say) after further review, I'm reversing the call and the Pio will go to the electronics graveyard under our bed or up in the attic.
Appreciate the responses.Marantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2 -
i gave up on the idea of an hdmi AVR in my bedroom rig as well...several reasons why, one of which was that its hard to find an hdmi AVR with a phono input and i wasnt that interested in getting a phono-pre....and the record player is mandatory so that was that.My Living Room
source > Sony DA555ES >
Kenwood GE-74 > Marantz SR4400 > Rotel RB980BX > Polk SDA2.
Pioneer VSX-D909S > Carver TFM-25 > Polk SDA1c.
Pioneer Elite VSX-99 > PSB imageB25.
Marantz 2226 > Polk SDA CRS.
Yamaha RX-V690 > Velodyne Servo F1000.
source > Onkyo TX-DS898 > B&W CC6 (center), B&W DM603, B&W DM601, B&W Rock Solid (rears), B&W AS6.
Bedroom
source > Pioneer Elite VSX-92TXH> ML Quest, B&W DM600 (center), B&W DM601 (rears), Velodyne Servo F1000. -
Denon AVR-391 or 591
