Can i run my amps mono each side?
scottyboy76
scottyboy76 Posts: 2,905
Have two adcom gfa5400s, 125 watts a side.
Also, im running a gtp540 pre.
Is there a safe way to run both amps to get more power to one set of speaks.
humpty dumpty was pushed
Post edited by scottyboy76 on
    edited January 2012
    What speakers you talkin' here ?
    heiney9 Posts: 25,488
    edited January 2012
    No, they are not bridgeable. They are stereo amps only.
  • decal
    decal Posts: 3,205
    edited January 2012
    ^^^^ What H9 says ^^^^
  • scottyboy76
    edited January 2012
    what i figured, thanks for affirming.
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    You could bi amp. Have to split the out from the mains on the 450 pre but it would work.
    oops you said 540 pre. not 450. it would still work though.
    I bet you mean 450 though.
    Too much **** to list....
