Trilams in the RTi150s???
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2004
    Thanks,
    If RTi150 tweeter is silk then I too love Silk. Silk is King.
    My new RT150i is queen. Going back to Silk tonight.
    Originally posted by dorokusai
    Silk is King.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • disneyjoe7
    edited April 2004
    Ok, my RTi150's are back to Silk. Tri-lam is out. I don't think it was a bad change not as easy as I would have expected but, again smooth.
    If you like the Tri-Lam tweeter then I would say try it out. It's ok IMHO.
    Here are some new pictures I promised.
    This one is showing the height difference of both tweeters. This reduced height is caused by the magnet change. (I think is a shielding magnet, I believe)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited April 2004
    Again the tweeters next to each other.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited April 2004
    The smaller back opening on the RTi150 causing fit & finish problem.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    VR3 Posts: 29,389
    edited April 2004
    I hear ya man.
    I had the RT35i playing with the RTi70 woofers for like...10 seconds, and then I unplugged it and switched them back with the RT5.
    Very shrill, didnt mate well with the RTixxx woofers one bit.
    Thanks for doing the test. Very cool.
