Denon vs Yamaha?
BigBankBii
I have a choice. To be primarily used as a pre-amp: Denon AVR 1907 or Yamaha V659?
To be combined with HK amp..
Harman Kardon Sig. 2.1 (100x5)
Denon AVR 1907
JBL LX 44's
TSI series Center and Surrounds
Klipsch Synergy 12 sub
Disapproving Wife
LG 46" LCD
PS3
DirecTv
Comfy-**** couch
Denon AVR 1907
JBL LX 44's
Disapproving Wife
LG 46" LCD
PS3
DirecTv
Comfy-**** couch
Post edited by BigBankBii on
I don't think the Denon has pre-outs except for the +2 channels. Is that right? The Yamaha does. Were you looking to just drive the second zone or surrounds with an amp?Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
The Denon does have preouts. In fact, both receivers are pretty damn close to identical in functionality. I guess I'm really asking an opinion on sound quality as compared between the two brands.
Im currently using the 5 channels of my HK amp for f,cente, and rears, with 2 channels running to a second zone elsewhere in the house powered off the Denon.Harman Kardon Sig. 2.1 (100x5)
Denon AVR 1907
JBL LX 44's
Disapproving Wife
LG 46" LCD
PS3
DirecTv
Comfy-**** couch -
I would recommend Yamaha. Sure, it may be a bit bright but IMO Yamaha is a much more reliable brand than Denon. I've owned 3 or 4 Denon receivers over the years and had problems with every one of them.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
I have had two Yamaha's and one Denon. Like HT said, the Yamaha is very reliable. However, my Yamaha's don't hold a candle to my Denon in the sound department. I guess a lot of what you hear will depend on the speakers your are pushing. My Yamaha was pretty bright on my RTi's and the Denon has a nice warm sound.
Denon....of those 2 choices considering the speakers.HT SYSTEM-
lsi 9's -
I have to say Denon with those speakers also. I prefer the Denon sound over Yamaha anyway.
ive never owned a denon so i cant truthfully say how they sound and if they break down all the time (but ive read a lot that says both). what i can say is that ive owned a small handful of yamaha's and they have never failed, or broken or whatever you want to call it...even when pushing current hungry speakers....they just work...their sound though, could be improved on which is why i only use them now in budget rigs. (my bedroom and my office)My Living Room
source > Sony DA555ES >
Kenwood GE-74 > Marantz SR4400 > Rotel RB980BX > Polk SDA2.
Pioneer VSX-D909S > Carver TFM-25 > Polk SDA1c.
Pioneer Elite VSX-99 > PSB imageB25.
Marantz 2226 > Polk SDA CRS.
Yamaha RX-V690 > Velodyne Servo F1000.
source > Onkyo TX-DS898 > B&W CC6 (center), B&W DM603, B&W DM601, B&W Rock Solid (rears), B&W AS6.
Bedroom
source > Pioneer Elite VSX-92TXH> ML Quest, B&W DM600 (center), B&W DM601 (rears), Velodyne Servo F1000. -
I have been using a Denon (4310CI) coupled with external amps for well over a year. Never had a single problem with the Denon in terms of reliability. Nonetheless, I have read that some folks have had problems with various models manufactured over the last few years.
My only complaint is the owners manual (for me) is horribly difficult to decipher. -
The XX07 series are fairly "reliable". I gave a friend an AVR 887 (which I believe is like a 2307). And I upgraded, at that time to an AVR 2807, still in my basement system with an all Polk bookie Rti system and Polk sub. Denons love Polks! At least the older ones did!
So yea. Denon. Those lower end Yammies are a bit too bright for me. Whereas the Denon is just right. But Upper level Yammies are pretty good. They sound better to me!
Have fun!
cnh
I second that lower-end yammies are bright. I have this, and I wanna change. However, my mother have a Denon AVR and Polk RTI4, and it's a tad more neutral than my yamaha...Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
Receiver: Denon X3500H -
Yamaha is my vote
I've owned both and preferred the Denons I owned over the Yamahas I owned by a mile.
LOL I have a 4310CI (fantastic AVR) and agree the owner's manual is like reading a foreign language... I went here: http://batpigworld.com/setup.html and learned everything I needed to know about how Denons operate. -
You can't have other people decide on sound for you. Whatever sounds best to you. Everyone hears things differently and likes different kinds of sounds.
This is a lot like a FORD vs CHEVY question...
If you bleed blue then Ford is what you buy, if you like to calling your Ford owner friends over for a tow, then you buy a Chevy. There's just no right answer.... :razz:Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
