Remote Controls
StewToMyLou
I am looking for some advice on remote controls. I have Uverse and the remote will not control my Denon Avr-391 besides turning it on and off.
I am looking for a all in one remote that can handle the TV, Receiver, DVR, Blue Ray Player and possibly the X-Box 360 if that is even possible.
I would like to stay under $100 bucks but as always cheaper is better.
Thanks for any suggestions.
Post edited by StewToMyLou on
Check out the Harmony's - that's pretty much the cream of the crop and should handle all of that easily65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
I just got the harmony 1100 and it was one of the best electronic buys I have made in a long time. Amazon had the best price last month...
The Harmony 600 or 650 might also suit your needs.I have the 600 which will control up to 5 devices.
Monster AVL300. It's RF capable, will control Z-Wave lights, and comes with an RF-controlled IR repeater called a Unilink. You can set the remote to operate strictly in RF mode, having the Unilink in a fixed position in front of your equipment sending the IR commands. That's how mine is set up to operate. Never have to aim the remote.
Amazon sells them for $70.
