Should a Squeezebox Touch be able to...
PSOVLSK
be moved between home audio systems? I have a 2-channel system in my computer room for more critical listening and another system in the living room for listening while doing stuff around the house. Shouldn't I be able to move my Squeezebox Touch between the two systems? The problems I'm having are fairly inconsistent, which makes it all the more irritating. Sometimes when I move from one system to the other it works fine. Sometimes Pandora is there, sometimes it isn't. Sometimes my Favorites are there and sometimes there aren't. A couple of times it has re-loaded all of my Pandora stations so that I have each station twice.
Shouldn't I just be able to just unplug it from one system and hook it up to the other? Not the ideal situation, but shouldn't it work?
Post edited by PSOVLSK on
I think ideally, they aren't meant to be moved around often. The Touch is always "on" even though the screen is blank when ("soft") powered off. I noticed when I powered mine down completely to hook up the new power supply, it took it awhile, and I had to stop/re-start LMS on my computer for it to find my library.
Next time you move it, stop/re-start LMS, then power up the Touch---see if that helps.
My duet controller sometimes has "hitches" where it acts like it's not getting a signal, when I know it is (it's only 15ft from my modem) and it'll just freeze; requiring a power down/power up cycle to get it working correctly. Although the whole time I'm doing this, the Touch continues to play without a hitch. The wireless signal strength to my Touch is 100% per LMS.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Every time you unplug it, your asking it to re boot the whole system which may take some time. Best bet may to pick up another squeezebox for the other room. This was one of the limiting factors which made me go the Sonos route though be it more expensive, just took alot of the hassles out of going wireless.HT SYSTEM-
lsi 9's -
Probably pulls a different IP address when you switch it. Has to re populate everything I'd imagine. I don't really know for sure.
I've thought about picking up a second receiver for this purpose. I know the remotes can connect to multiple receivers. Might be a worthwhile option.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
I think you may have nailed it Steve. I've moved it twice tonight with the LSM running on my computer and I've had no issues.
At any rate, I'm buying the Classic in the FM for convenience and for fear of messing something up on the Touch by continually unplugging/restarting.Things work out best for those who make the best of the way things work out.-John Wooden -
+1 There's a reason the Sonos is a little more pricey...those problems just don't exist with the Sonos. It's own built in wi-fi system is what makes the difference. Picking up another Classic as you mentioned will hopefully take care of the problem you're having. -
Problems? What problems? How is this a "limiting factor"? Nobody ever moves a CD player or a turntable from room to room... Put a SB receiver in every place you need one, and there's no problem at all. That said, I recently moved one from my basement that supplies an outdoor zone that's unused this time of year. Put it in my bedroom and had no problems at all. Looks like I'll be in the market for another one also, and that's the best solution.
mdaudioguy wrote: »Nobody ever moves a CD player or a turntable from room to room...
That's a good point. I never looked at it from that perspective. I guess since it's such a small unit I consider it to be portable.Things work out best for those who make the best of the way things work out.-John Wooden -
I've not ran into this problem. I pulled the SBT when I reinstalled my components, new receiver along with a new power supply for the Touch. I have mine connected over lan cable though, so not sure if it would be different depending on connection.Shoot the jumper.....................BALLIN.............!!!!!
