FS: Parasound HCA-3500, Mint Condition
sm88
sm88 Posts: 353
edited October 2012 in For Sale (FS) Classifieds
This 85 lb beast has been a wonderful amp for me but has far more power than I need and I could use the cash now so i'd rather pass it on to someone who can appreciate it more! It's flawless from what I can see, not a scratch. Has handles for easier carrying, I do have the original double box and packing materials so shipping is a possible option but I would rather sell this locally.
I suppose i'll start it for $1200. Since it is my only amp currently I would also consider partial trades; i'm looking for something in the $300-400 range. One of the lesser Parasounds would fit the bill, as would an Anthem MCA20, or Rotel amp.
I live near Boston, MA. Thanks! Specs below
FEATURES
Independent power supplies for each channel for true dual-monaural operation
Massive encapsulated 1.4 kVA toroid power transformer for each channel
97,600 uF power supply capacitance for each channel
Multiple polystyrene film bypass capacitors in power supply
Direct coupled design uses no inductors or capacitors in the signal path
DC servo direct-coupled audio circuits with 0.5 Hz rolloff
Output transistors direct-coupled to speakers without LRC networks
Cascode Class A input stages with matched J-FET pairs
Hand-picked complementary MOSFET transistors in high voltage driver stage
High-bias Class A/AB operation provides 15 Watts of pure Class A operation
8 complementary pairs of 15 ampere 60 MHz output transistors per channel
High-quality Neutrik XLR jacks for balanced inputs
Two sets of gold-plated metal structure RCA input jacks for balanced operation
Two sets of gold-plated 5-way binding posts facilitates bi-wiring
Multiple protection circuits, temperature sensors and silver-cadmium relay protection
Glass epoxy circuit boards, double-sided for precision
Two hand-made audiophile-grade AC power cords-separate for each channel
SPECIFICATIONS
Continuous Power Output - Stereo:
350 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven;
500 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
Current Capacity:
120 amperes peak per channel
Slew Rate:
> 200 V/?second
Power Bandwith:
2 Hz - 150 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion:
<0.025% at full power; < 0.01% at typical levels
IM Distortion:
<0.03%
Current System:
Paradigm Signature S2 v2
Conrad Johnson MF2500
Wyred4Sound DAC2
Audioquest Black Mamba II
For Sale:
3x Wilson Cub's
  • chumlie
    chumlie Posts: 8,658
    edited January 2012
    /\reported/\
  • PrazVT
    PrazVT Posts: 1,607
    edited January 2012
    120 amps peak - now that is high current! Awesome amp. Good luck w/ the sale!
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
    EndersShadow Posts: 17,765
    edited January 2012
    Pics always help as well, suggest posting some later tonight if you can....
    pitdogg2 Posts: 27,918
    edited January 2012
    common ground?
  • cstmar01
    cstmar01 Posts: 4,424
    edited January 2012
    I don't think this one is. Its a dual mono design so I think when I contacted Parasound they said that all their amps besides this one and the JC Mono are the exceptions for being used with SDA's.
    edited January 2012
    I was pretty sure of that but thought i'd toss it out there. just in case someone thought of using it for SDA's
  • sm88
    sm88 Posts: 353
    edited January 2012
    I had to go find the camera charger so i'll get some pics up later when the battery is charged, but besides a bit of dust it pretty much looks brand new. As far as common ground goes I am not sure but this amplifier takes TWO power cords and each channel is turned on separately by a front switch. It is an awesome design with huge power reserves, plenty for any speaker I can think of. Thanks for the interest so far!
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • dorokusai
    dorokusai Posts: 25,661
    edited January 2012
    It should be common ground. Dual mono is just the core design principle. It can easily share a ground and still be a dual mono design. My CTC BBQ is common ground and so has every other amplifier I've owned from Parasound.
    I'm not surprised that a JC1 monoblock isn't common ground....since it's a MONOblock.
  • audiocrawl
    audiocrawl Posts: 3
    edited January 2012
    Not such a bad price for Parasound HCA-3500
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2012
    The HCA 1000 is also a dual mono design and works well with SDA. I contacted parasound and they said there should be no issue. Should be the same amp design, just with a couple more transistors.
  • fossy
    fossy Posts: 1,378
    edited January 2012
    god I wish I had the money ...... anyone thinking of going into seperates ...... anyone wanting a bad as* amp .... this is the one
  • gdb
    gdb Posts: 6,012
    edited January 2012
    I would if I could. GLWS !
  • sm88
    sm88 Posts: 353
    edited January 2012
    Couple of quick dusty flash pics. Not a scratch on this amp, i'll dust it and make sure there aren't any marks before I finalize any sale just to be sure though. It absolutely fits the "large and in charge" bill! I'll drop the price to $1100 to make it more accessible to non-locals. I've owned a lot of Parasound amps and some of them tend to get very hot, I will say that with my usage thus far this amplifier does NOT become a griddle like others. I bought it from the original owner; both of us are smoke free and pet free.
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • thejck
    thejck Posts: 849
    edited January 2012
    i have this amp.. very nice amp. I use it to drive my 1.2's
    I would love to have this just cause i love it so much but that doesnt make sense to have 2. :) good luck with your sale.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited January 2012
    sm88 wrote: »
    Well if you're going to throw in the DAC 2 on me like that I'll take it! ;P
  • wkjeffers
    wkjeffers Posts: 139
    edited January 2012
    this is a powerful amp, wish I had room for it!
  • sm88
    sm88 Posts: 353
    edited January 2012
    I wish I could include it! I might sell the Wyred4Sound DAC2 a little later, would likewise need a replacement though (probably a dacmagic). Another amazing piece of equipment.
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • audiocr381ve
    edited January 2012
    sm88 wrote: »
    Why the downgrade? (to a dacmagic)
  • sm88
    sm88 Posts: 353
    edited January 2012
    I work as a waiter in fine dining and am typically very successful, especially over the summer, but the restaurant I am at is new and hasn't really established itself yet. The summer was great but business tanked after Christmas and i'm basically out of work, I only go in a few times a week and it's never for a lot. Coupled with smashing the door on my car by accident and having to buy another vehicle that can actually drive in the snow.. audio equipment very quickly becomes an expendable luxury. I want to keep the speakers and enjoy them, but I can live with a lesser amp and a lesser DAC for the time being.
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • sm88
    sm88 Posts: 353
    edited January 2012
    -bump-
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • sm88
    sm88 Posts: 353
    edited January 2012
    -bump-
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • kenyer
    kenyer Posts: 5
    edited January 2012
    sm88 wrote: »
    -bump-
    I am looking for a high wattage amp of good quality and like new condition and wanted to ask if you would be interested in taking my Pioneer SA 9900 that was restored by my friend Terry Dewick this past summer?
  • dorokusai
    edited January 2012
    This is a last amplifier type of amp....and it should seriously be considered by those looking to end the amp search.
  • sm88
    sm88 Posts: 353
    edited January 2012
    kenyer wrote: »
    I love the vintage look of that amp but i'm looking for separates, don't need the extras as I have a DAC with a decent Pre function. I think this amp would exceed your expectations, it is built like a tank, has room for upgrades should you ever wish to get more out of it, and will drive pretty much any loudspeaker you might have to ear bleeding levels. Whereabouts are you located?
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • audiocr381ve
    edited January 2012
    sm88 wrote: »
    If you listed this in the 'gon it would be GONE by now.
  • kenyer
    kenyer Posts: 5
    edited January 2012
    I'm in Daytona Beach..Just moved here from Kingston TN 4 weeks ago..Terry lives about 30 min from me in Knoxville which was very nice anytime I needed something worked on or just wanted to hang out and talk while he worked on stuff at his bench
  • danz1906
    danz1906 Posts: 5,144
    edited January 2012
    Great Amp........Good luck with the sale!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • sm88
    sm88 Posts: 353
    edited January 2012
    I'm very appreciative of everyone here on the Polk forum, so I prefer to give my friends here a chance on anything I sell before it goes off to Audiogon at a higher price :)
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • dorokusai
    edited January 2012
    SM88 - I'm interested but have to move something of my own first. If you're not a huge hurry, I can't possibly let this amplifier head to Audiogon if at all possible. I have absolutely ZERO use for it but it's THAT good and so powerful, that we gotta keep this one in the family. Hit me up offline thru email here and let's talk.
  • kn505
    kn505 Posts: 380
    edited January 2012
    Are you interested in a partial trade with a Musical Design D75?
    WAP4410NI am in Hartford and can meet you in Boston.
