Trilams in the RTi150s???
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited April 2004 in Speakers
Two questions:
Would it be possible and relatively easy to put a pair of trilaminate tweeters in my RTi150s?
Is that a good idea, or would differences in design, crossover, etc make this a bad idea?
I really like the sound of the trilams a little better than the Silk/Polymers I have now, but am not willing to get rid of the 150s becuase the like the mids and bass...just thinking out loud...
Post edited by AsSiMiLaTeD on
    F1nut Posts: 51,761
    edited April 2004
    Ed Zachary!
  • AsSiMiLaTeD
    edited April 2004
    Originally posted by F1nut
    Ed Zachary!
    How'd I know that was going to be the case...
    Oh well, worth asking anyway...
    I love the 150s, just thought if I could get the trilams in there I'd have my ultimate speaker...at least in my price range...
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2004
    It is certainly a workable idea, but it is not a drop in replacement.
  • AsSiMiLaTeD
    edited April 2004
    I think this will be a good project for me one of these days...
    I've noticed that several people around here are into 'customizing' things a bit, think I'm gonna venture into that a bit as well...
    As I'm in Texas, I usually go into hibernation in the summer becuase of the heat...should give me some good projects to work on...
  • gmorris
    gmorris Posts: 1,179
    edited April 2004
    Why would you want to put the Fraternity from Revenge of the Nerds into your speakers?
    (Trilams, get it, ha ha ha)
    Bob Mayo, on the keyboards. Bob Mayo.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2004
    Can you explain, different case ? Crossover needs to be reworked :eek:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • AsSiMiLaTeD
    edited April 2004
    I would think that the crossovers in the speakers are built to work best with the tweeters and driver...therefore changing either may not work too well with the crossover...
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited April 2004
    Sounds like he might need to be as smart as one of the tri-lams to get that mod done right. Sadly I can't be of any help, as I haven't anything in common with the tri-lams, save for Poindexter's premature disorder.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
    VR3 Posts: 29,427
    edited April 2004
    The Tri Lam (IE The RT35i with a baffle)
    and the RTi150 Silk (Baffle).....
    IT IS A DROP IN REPLACEMENT.
    It fits in nicely, I have tried it :D
    Ken sent me a silk replacement for my tri lam in the rt35i, it fitted in perfectly. But I didnt need it as I discovered it was a crossover problem.
    Try it out.
    The baffle's are the same between series -- they snap in, snap out.
    To my knowledge the original rt series that used the baffle, the non I, (RT25, rt35, rt55) -- used a smaller baffle.
  • AsSiMiLaTeD
    edited April 2004
    Try it out.
    You don't think I'll have issues with the different crossovers?
  • faster100
    faster100 Posts: 6,124
    edited April 2004
    I don't believe any one has actually tried it, and I know Ken will send the parts to test it out.. I would think the specs of each tweeter are very close and could be tested safely to see what the results were... after all, they changed the material the tweeter was made of only for the most part? NO?
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    VR3 Posts: 29,427
    edited April 2004
    The Silk and the Tri Lam are pretty much the same.......
    BUT.......
    The Sonic differences are huge, the Silk (to Me) is not near as good as the Tri Lam or other past Polk tweeters.
    The crossover issue, NAH.....
    Try it out
  • AsSiMiLaTeD
    edited April 2004
    BUT.......
    Try it out
    Yeah, I've always loved the tri-lam sound...the Silkds aren't bad, just not as good to me either...
  • dorokusai
    edited April 2004
    I meant drop in Trey, as in no changes internally, not just fit and finish :rolleyes: I would check with Ken before I would move forward simply on a "Nah" comment.
    kswauger@polkaudio.com
  • AsSiMiLaTeD
    edited April 2004
    I sent him a PM...maybe should use email instead?
  • dorokusai
    edited April 2004
    Yes.
  • disneyjoe7
    edited April 2004
    Was this reference for me?
    If so here's something I've been working on. Getting ready for market, just needed to "find" the cash first. ;)
    http://bellsouthpwp.net/g/o/goofy8/
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited April 2004
    Two questions:
    NO
    NO, Little metal, Nothing IHMO, YES.
    Keep them just like they are, and stop dreaming of the Tri-Lam's.
    Posing the New Polk Audio, RT150i
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited April 2004
    Poor fit due to bigger magnet on tweeter of the Tri-Lam.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited April 2004
    Fit & Finish 2
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited April 2004
    The smaller magnet size on the RTi150 tweeter. The Tri-Lam tweeter works ok, I don't hear any problem with crossover point or anything like that. I just wouldn't keep this like this. I don't care for the Tri-Lam sound IHMO.
    If you do go for it, but you will have to make to back hole for tweeter a 3/16" deeper or so.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    VR3 Posts: 29,427
    edited April 2004
    Hmmm.....
    I guess the hole in the RTixxx line is different than the RTxxxi line. I never switched out the RTi70, but the baffle should be the same.
    I have my silks unplugged, and they arnt coming back.
    But I know why you dont like it, I stacked my RT35i on top of the tweeterless RTi70 today and immediately put them back on surround duty.
    Very bright, very disturbing, I did not like it at all.
    The RT5 by far is my FAVORITE speaker of the 3 pairs I own by Polk. They have AMAZING highs, KILLER mids and decent bass. The highs excell above and beyond the Silk and the Tri Lam (to Me). That is why I am stacking them and have the silk unplugged.
    Sorry to hear it didnt work out, and surprised the magnet on the tri lam is bigger than the silk??
    Also if you open up the Silk and the tri lam, there is more damping material inside the tri lam than the silk??
    Either way, if I had to choose my favorite of the three...
    1) Polymer
    2) Tri Lam
    3) Silk
    The Silk to me is overly bright, harsh and annoying - alone or in the stacked configuration. It just dosnt sound good to me, which alas is why I have it unplugged. But the Polymer in the RT5 is all around smooth and seamless with the driver setup. I really enjoy it.
    All my opinion though.
  • disneyjoe7
    edited April 2004
    Sid,
    1st what do you call the RTi150 tweeter?
    1) Polymer
    2) Tri Lam
    3) Silk
    2nd the RTi150 tweeter back magnet is not as deep. I will post picture of the Tri-Lam tomorrow so all can see the difference.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    VR3 Posts: 29,427
    edited April 2004
    the RTi150 is a Silk/Polymer Dome -- but to me it is plainly a silk, and lacks the detail of both the Polymer and the Tri Lam. Take a Tri Lam speaker full, then a silk/polymer (RTixxx line), play the same song. There are several things missing (atleast to me) in that same song. Particularly in the cymbal, snare, and acoustic guitar area.
    The Polymer in the RT5 even shows this more (to Me).
    The RT5 is a Polymer Dome
    The RTxxxi line is a Tri-Lam Dome
    The Silk is a nice tweeter, but its just not my cup of tea.
  • AsSiMiLaTeD
    edited April 2004
    cool, thanks for the demo...
  • dorokusai
    edited April 2004
    Excellent work DJ, thank you for taking the time to do all that, and take pictures! ....any questions Trey? :)
    The crossover point, and whole crossover issue is going to be dependent on more than an ear. It may very well be small or it could be large on the gun, that would be a more labor intensive swap.
    Sidenote: If I never hear another SL2000 in my life, I will die happy.
    VR3 Posts: 29,427
    edited April 2004
    No questions here.
    lol, sorry about before. I thought you meant external changes. I had no idea the enclosure hole for the tweeter would not be deep enough. Surprised there.
    The SL ---- TL replacements are STELLAR man.
    BIG IMPROVEMENTS, IMO.
  • weavercr
    weavercr Posts: 289
    edited April 2004
    I dont know the impedance of the speakers? or the other thiele small parameters.
    Polks speakers that are using the trilam as crossovered ar 2.0 k on the RT1 35, 55 and 800. while the silks on the rti 38 are 2.4k, rti70 2.1k and RTi 150 are 2.4 k.
    The cutover frequency will not cause a problem, but what are the spl of both tweeters, this will change the entire balance of the speaker if they do not match. Crossovers may have a built in -db attenuation to balance out different spl ratings.
    So without knowing all of the thiele small parameters of both speakers, your shooting in the dark.
  • disneyjoe7
    edited April 2004
    Thanks for the info. I was rethinking that there's something different with the crossover, due to the fact that "Sid the Kid" says that silk is louder. I find the silk not as loud and the Tri-Lam louder. The Silk tweeter smoother then the Tri-Lam tweeter.
    So with this info find that if tweeters are swapped troubles can be found. I would think that crossovers may level out sound for the given design of speaker. So in turn there's a balanced speaker sound. :cool:
    I will be changing the tweeter back. I will then post pictures of both tweeters and the back area of speaker that was not deep enough.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dorokusai
    edited April 2004
    Silk is King.
