Is fine tuning w/EQ, SPL Meter, and Test CD worth the effort?
DonEmmel
All,
I recently balanced the SPL output from each of my speakers using the Test Tone(pink noise) setup on my Sony STR-875 receiver. I used a Radio Shack decibel meter. I am considering buying a test CD which hits the frequency response curve in several increments. Using the EQ on the STR-875 I was going to level the response curve of each of my speakers. The EQ has 81 steps per channel. If I did this for each speaker(except sub) I would have to adjust 405 steps total. Is this really worth the effort? Will I hear a significant difference in the quality of the audio output of my system?
Speakers: CS245i (Center channel)
RT55i (Mains)
RT35i (Surrounds)
PSW450 (sub)
RT55i (Mains)
RT35i (Surrounds)
PSW450 (sub)
Post edited by DonEmmel on
BY ALL MEANS YES it was the simplest and biggest improvement
i made to my whole system
my center was way to load and my rears need coming up a few notches,,,, and there is now way you can do it by ear
:eek: :eek: :eek:
i used video essentials and campared to my recivers internal test tones, well my recivers were way off...
I bought a SPL from RS too. and it made a big difference in the sound on my system too. You'll never be able to do it by ear like jdog1 said. he is 100% right on.
Also use a test/set up DVD for pink noise and phase test. I found it's more accurate than the one built into the receiver. I don't have the AVia one that lots of other folks have.. i will some day. use one from Discwasher.. it will help you set up your Dolby digital, prologic and DTS systems.PolkFest 2012, who's going>?
AVIA (or your set-up disc of preference) and a SPL meter are the cheapest tweak, with probably the greatest results for your effort. very worth the money and time! you can get a better result setting your system up properly rather than spending hundreds in an upgrade...
I concur with all of you. One must buy Avia or VE (or one of the other many setup discs) to properly set up a system. The internal test tones just don't cut it and can be off by as much as +-3 db!
I don't know if an EQ is really necessary, but if you have the time and money, by all means, go do it. -
What do these meters run price wise?
$30 for the analog
$60 for the digital
Aaron
