3 single voice coil subs how to wire?
Systems
Systems Posts: 14,872
edited April 2004 in Car Subwoofer Talk
I'm gettin the momo 10's the original ones with the metal cone.. i'm trying to figure a way to wire them off of 1 or 2 amps.. any suggestions?
Testing
Testing
Testing
  • exalted512
    exalted512 Posts: 10,734
    edited April 2004
    parallel into a 1.333 load
    need an amp that does like 1600x1@1 ohms
    -Cody
  • jamas33
    jamas33 Posts: 89
    edited April 2004
    The Kenwood Excelon KAC-X810 does that. If you are interested let me know. I friends at Kenwood and I can seriously save you some money.
    Equipment List:
    Head Unit: Kenwood Excelon XXV-005
    Planet Audio P13.3
    Ipod 60 GB
    XBox
    AMPS:
    Kicker KX1200.1
    Kicker KX850.4
    Speakers:
    Front: Kicker RS65
    Rear: Kicker RS65
    Rear Deck: Pioneer 4x10 (AAARGH)
    Subs: 2 Kicker 15L7
    my car: http://www.cardomain.com/ride/571313
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2004
    how much can you get one of the graphic 13 band eq's for?
  • jamas33
    jamas33 Posts: 89
    edited April 2004
    Give me the model number and I will ask them.
    Equipment List:
    Planet Audio P13.3
    Ipod 60 GB
    XBox
    AMPS:
    Kicker KX1200.1
    Kicker KX850.4
    Speakers:
    Front: Kicker RS65
    Rear: Kicker RS65
    Subs: 2 Kicker 15L7
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited April 2004
    the x810 does not do 1500 or 1600 watts rms! ... last i recall it was like an 800 watt mono amp.
    The Artist formerly known as PoweredByDodge
  • jamas33
    jamas33 Posts: 89
    edited April 2004
    my mistake. I wasnt paying attention... Its not rms that thing maxes at 1600 but is 1 ohm stable.
    Equipment List:
    Planet Audio P13.3
    Ipod 60 GB
    XBox
    AMPS:
    Kicker KX1200.1
    Kicker KX850.4
    Speakers:
    Front: Kicker RS65
    Rear: Kicker RS65
    Subs: 2 Kicker 15L7
  • exalted512
    edited April 2004
    yeah, you need a 1600 watt RMS amp
    not peak:)
    -Cody
  • neomagus00
    edited April 2004
    if needed, the subs can be wired to 1.6 ohms instead of 1.33. this may make a 2 ohm stable amp less upset, should that become necessary. for 1.6, two are in parallel, and that setup is in series w/ the third.
  • Systems
    edited April 2004
    Thanks fellaz.... i think i'm just going to stick with 2 10's for now... and then upgrade to four later.... do you think that one of the new mono plkc5001 will run those 2 subs fine.. or should i get 2 amps
    Testing
    Testing
    Testing
  • neomagus00
    edited April 2004
    hey jamas33 - the model is KGC-9044, MSRP $350.
