AMP's for less than $1000
justlord
justlord Posts: 33
edited January 2012 in Electronics
I am a Home Theater enthusiast (but enjoy music between 30 and 50 percent of the time) that is just realizing the benefits of powered amps. I am just about to upgrade to the RTI-A7 and -A6 for my front-stage, and I intend to run my Onkyo NR-807 as a pre-amp for those speakers. Those who have Onkyo's have indicated Emotiva's sound bright with the RTI series. I am considering 3 and 5 channel amps, but wouldn't mind the 2 channel amps, either.
I would prefer to start off brand new for now and pay less than $1000 to boot. I am still serious about Emotiva XPA-5, but willing to consider other options, such as the 2 and 3 channel amps for less than $1000, and with enough authority to take the powered sub out of the music if I wanted to.
Post edited by justlord on
  • chumlie
    chumlie Posts: 8,658
    edited January 2012
    Can you say Parasound, Carver, Marantz ?
  • shawn474
    shawn474 Posts: 3,052
    edited January 2012
    IMHO, used is the way to go. A well taken care of amp can last a long long time and you would greatly increase hour selection.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • PrazVT
    PrazVT Posts: 1,607
    edited January 2012
    Yeah I'm seeing a Rotel 1095, NAD T973, Sunfire Grand (200 x 5) in the $800 - 900 range on quick check of Audiogon.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • thsmith
    thsmith Posts: 6,082
    edited January 2012
  • la9ers
    la9ers Posts: 117
    edited January 2012
    Your best bet is to go used, at 1k your limited.
    edited January 2012
    You can find Parasound, B&K, Rotel amps all day used under a grand, and alot under 500 even.
  • Systems
    Systems Posts: 14,872
    edited January 2012
    Used:
    McCormack Audio Corp.
    2733 Merrilee Drive Fairfax, VA.
    22031
    703-573-9665
    Testing
    Testing
    Testing
  • Systems
    edited January 2012
    Here: http://www.mccormackaudio.com/index1.html
    You may be able to find one used under $1k.
    Look for the DNA .5 or 1, or the DNA 125 used.
    Testing
    Testing
    Testing
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2012
    If you want new, your only choices are really Outlaw Audio or Emotiva. You can get 3 Outlaw monoblocks for $1050.00, or an Emotiva XPA 3-5. These are the only companies right now that make reasonably priced gear brand new.
  • Sherardp
    Sherardp Posts: 8,038
    edited January 2012
    Outlaw, Sunfire, Emotiva, Adcom, Parasound are some that may be close. Wyred 4 Sound, might be close but don't quote me on that one.
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    This is about the best deal you are going to find.
    http://www.polkaudio.com/forums/showthread.php?128255-Adcom-Sunfire
    Too much **** to list....
  • justlord
    justlord Posts: 33
    edited January 2012
    Thank you everyone for your replies. Your answers are what I suspected. I have seen the website audiogon mentioned several times. Since these items are typically used, what payment options are typical for this website, and is there a seller's rating to look out for?
  • rengnath
    rengnath Posts: 118
    edited January 2012
    I personally have used eBay in the past few weeks to pick up some amps. I found a B&K ST2140 for $290 shipped and my brother picked up 2 Parasound HCA1000As shipped for under $700 that he will run in mono and squeeze 400 watts out of each. Typically when looking at used, I look for any amp that you can tell the seller used it for their personal use, and they are selling it due to money needs or an upgrade. There are alot of sellers that you can tell just found the item at a yard sale or they bought it or they bought it non-working and fixed it. Audiogon had alot of nice amps when I was looking, but eBay seemed to have a better selection of budget amps.
    AVR - Yamaha Aventage RX-A800
    Amps - B&K Components ST2140 (for mains) and Parasound HCA-1000A (bi-amping center)
    Mains - RT1000i Towers
    Center - CS400i
    Sub - BIC Acoustech PL200
    My neighbors listen to very good music, whether they like it or not :cheesygrin:
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited January 2012
    justlord wrote: »
    I would visit the website, you'll find all the info you need there.
    There are some amps in the for sale section that you should take a serious look at. The Parasound HCA-3500 might still be there :eek: (although a little out of your price range)
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited January 2012
    rengnath wrote: »
    Just remember that in bridged mode (mono) these amps cannot handle 4ohm speakers, just something to keep that in mind.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
