Can a 20 Amp Signal Power Cord be used on SC-35 ?
larry777
larry777 Posts: 480
Can the 20 amp rated version of the Signal Power Cord be used with my Pioneer SC-35 receiver ? I obviously don't need this cable to provide 20 amps, but will it still work ok as an upgrade to the stock cable ? ( Lets say as compared to their 15 Amp power cord ) Or would you have to put in a 20 amp wall plug to match up with this 20 Amp cord ? I may be able to get one at a good price.
Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects
Post edited by larry777 on
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2012
    If it has the same plug type as the receiver. My 20 amp cables have plugs with horizontal pins. They only fit my amps, which have 20 amp sockets.
  • larry777
    larry777 Posts: 480
    edited January 2012
    When I doubled checked the plug type.......the 20 A female end did seem to be more square as compared to the 15 A version. It looks like it may not fit afterall . Thanks for the reply as it did help.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
