Tried Bi-amping with my 608
rebuy
rebuy Posts: 694
edited January 2012 in Speakers
I read a post from sprtdude91 where he said he bi-amped his RTI 9's or whatever he has and he said he got great results using his sc-35. So I said to myself, "what the heck, you should try it", and I did. Keep in mind I have a small room and run RTI4's, so it's not like I'm trying to power up big speakers.
The results are ear opening. My RTI's sound much better than from straight wiring with jumpers. The sound stage is bigger and more open. The woofer/mid and the tweeter seem to perform much better. Wired up this way with my AVR it seems to capture recordings much better and give you a better acoustic performance of the session. Instrument separation is much improved and tones ring more true.
I really am surprised by how different these speakers sound bi-wired from this Onkyo. I will keep them this way. I'm not saying this will work for everyone as I have a small room and small bookies.
Post edited by rebuy on
    F1nut Posts: 51,997
    edited January 2012
    Stock jumpers or aftermarket?
  • rebuy
    rebuy Posts: 694
    edited January 2012
    14 gauge that I made, bare wire contact. Did not really notice a difference in jumpers and stock bars.
    Speaker wire runs are only about 5 feet at most.
    F1nut Posts: 51,997
    edited January 2012
    Very good sir, enjoy.
