3 single voice coil subs how to wire?
Systems
I'm gettin the momo 10's the original ones with the metal cone.. i'm trying to figure a way to wire them off of 1 or 2 amps.. any suggestions?
Testing
Testing
Testing
Testing
Testing
parallel into a 1.333 load
need an amp that does like 1600x1@1 ohms
The Kenwood Excelon KAC-X810 does that. If you are interested let me know. I friends at Kenwood and I can seriously save you some money.Equipment List:
Head Unit: Kenwood Excelon XXV-005
Planet Audio P13.3
Ipod 60 GB
XBox
AMPS:
Kicker KX1200.1
Kicker KX850.4
Speakers:
Front: Kicker RS65
Rear: Kicker RS65
Rear Deck: Pioneer 4x10 (AAARGH)
Subs: 2 Kicker 15L7
my car: http://www.cardomain.com/ride/571313 -
how much can you get one of the graphic 13 band eq's for?It's not good, very fundamentally simply not good. - geolemon
Give me the model number and I will ask them.Equipment List:
Planet Audio P13.3
Ipod 60 GB
XBox
AMPS:
Kicker KX1200.1
Kicker KX850.4
Speakers:
Front: Kicker RS65
Rear: Kicker RS65
Subs: 2 Kicker 15L7
the x810 does not do 1500 or 1600 watts rms! ... last i recall it was like an 800 watt mono amp.The Artist formerly known as PoweredByDodge
my mistake. I wasnt paying attention... Its not rms that thing maxes at 1600 but is 1 ohm stable.Equipment List:
Planet Audio P13.3
Ipod 60 GB
XBox
AMPS:
Kicker KX1200.1
Kicker KX850.4
Speakers:
Front: Kicker RS65
Rear: Kicker RS65
Subs: 2 Kicker 15L7
yeah, you need a 1600 watt RMS amp
not peak:)
if needed, the subs can be wired to 1.6 ohms instead of 1.33. this may make a 2 ohm stable amp less upset, should that become necessary. for 1.6, two are in parallel, and that setup is in series w/ the third.It's not good, very fundamentally simply not good. - geolemon
Thanks fellaz.... i think i'm just going to stick with 2 10's for now... and then upgrade to four later.... do you think that one of the new mono plkc5001 will run those 2 subs fine.. or should i get 2 ampsTesting
Testing
Testing -
hey jamas33 - the model is KGC-9044, MSRP $350.It's not good, very fundamentally simply not good. - geolemon
